It is currently Fri Jan 19, 2018 3:01 pm
 Post subject: Hand rails on the PA
PostPosted: Mon Apr 23, 2012 9:27 pm
The bungies in my hand rail are comming apart, is the rail bolted through or blinde. can i take the bolts out with out having to crawl inside to reatach the nuts?
you hookem and i will fry um
 Post subject: Re: Hand rails on the PA
PostPosted: Tue Apr 24, 2012 6:42 am
You'll have to remove the rails from the boat. The bungees are threaded through the pipe (rail) and out through the nylon end and secured there with a knot around a small washer. The nylon ends are fastened, on one end, with a single rivet. On the other the end will just slip off. It's a not a big deal to replace the bungees.
PostPosted: Tue Apr 24, 2012 2:20 pm
Thanks will try Wed.
