It is currently Tue Jan 23, 2018 5:43 pm
 Post subject: Hobie 14 Rebuild.
PostPosted: Mon May 07, 2012 5:21 pm
I have recently picked up a Hobie 14 early 1970 model and it needs some TLC, there is some damage near the rudder bod where the fiberglass has torn out, it needs all new ropes because they were all left out in the weather for 20 years, and there is one thing I am not sure about, the boat has a trapeze but no jib so does that make it a H14T or a H14.
Any tips and tricks to do with painting them a different colour (1970's green does not cut it) and putting the right stuff back on would be nice also some tips with fiberglass repairs would also be nice.
Picture available at: http://www.sparocool.tumblr.com
 Post subject: Re: Hobie 14 Rebuild.
PostPosted: Thu May 10, 2012 6:54 am
That cutout in the lip at the rudder pin makes no difference at all unless it is leaking there. Racers used to cut this out in order to get more rake. If your boat doesn't have a dolphin striker it's not a 14T. Can't really tell from your photos.
PostPosted: Thu May 10, 2012 1:24 pm
If a am racing in a hobie 14 regatta am I aloud to use the trapeze? And no dolphin striker.
PostPosted: Fri May 11, 2012 11:15 am
Yes.
5.5 A single trapeze may be used during Class
competition. Wire length is optional. Adjustable
systems are optional.
See the class rules here:
http://www.hobieclass.com/site/hobie/ih ... 120401.pdf
It sounds like you have a common non Turbo H-14 which doesn't have the striker. As I understand it, the H-14 didn't have a trapeze when it was first produced, but it was added later.
Jerome Vaughan
Hobie 16
PostPosted: Fri May 11, 2012 3:27 pm
If you are going to trapeze on the 14, you should add a dolphin striker. All that extra weight (you) hanging from a wire attached to the mast ultimately puts more stress on the front crossbar. The dolphin striker acts as a brace for the crossbar.
Mark Van Doren
H14T Fantasia #47787
San Juan 28
PostPosted: Sun May 13, 2012 4:48 pm
How much would a dolphin striker set me back, plus the fact the I live in the south of Tasmania (Australia)
PostPosted: Sun May 13, 2012 7:50 pm
I'm sure there are Hobie dealers down under that would be happy to sell you a dolphin striker. There's two ways to buy one. 1) you can buy the individual pieces which include a new mast step, horizontal dolphin striker rod, and the verticle rod that passes through the mast step. Just think of a H16 dolphin striker and you've got it. The sum of those parts comes to $226 US through Mariner Sails, the Dallas, Texas, Hobie Dealer. 2) You can purchase the dolphin stiker kit from a Hobie dealer for $96 US. However, the kit, which I have on my boat and I feel is adequate, has a steel cable that runs horizonatally across the boat below the front crossbar and a post that extends down from the front crossbar to hold it in place. If you can't find a dealer in Australia that will help you out, try Mariner sails, http://www.mariner-sails.com. One member of their staff, John Webster, is a fellow Aussie and I'm sure he knows how to ship stuff home.
Mark Van Doren
San Juan 28
PostPosted: Thu May 24, 2012 2:58 pm
Thanks guys you have been so helpful but one more thing I was rigging the boat the other day and the ropes aren't going to cut it to say the least, and I cannot fund a list of the rope sizes and gauges for the whole boat would anyone be able to give me a list of the correct sizes?
Thank you
PostPosted: Thu May 24, 2012 4:40 pm
Have fun!
http://www.hcana.hobieclass.com/site/ho ... eGuide.doc
http://www.hobiecat.com/support/tech/h14tuning.html
PostPosted: Thu May 24, 2012 4:49 pm
Thank you
You are a life saver im going sailing in it tomorrow and i didn't want old ropes breaking
PostPosted: Thu May 24, 2012 4:54 pm
But i noticed that the traveler car rope is not on there, nor are the righting lines. do you know what to use?
PostPosted: Thu May 24, 2012 5:10 pm
The end of the mainsheet is run through the swivel cam cleat, the traveler car and then dead-ended at the eye strap on the crossbar. 5/16" will work for a mainsheet, as well, it's all up to your preference, especially what feels good to your hands.
http://static.hobiecat.com/2010_archive/support/pdfs/e_h14manual.pdf (Figure 36)
As far as righting lines, there are many different options there. Some people tie a single line around the dolphin striker, or center of front crossbar, while others run a line around the pylons that have a bungee cord in the center to automatically retract it. If you have the old mainsheet, that would be good to take along. The righting line has to big enough to grip it easily and it has to be long enough to do its job. The Hobie 16 Assembly Manual recommends 1/2" poly rope, 15 to 20 feet long.
Check out page 22.
http://static.hobiecat.com/digital_asse ... ries_1.pdf
The "Hobie 16 FAQ's" has pictures showing how to lace the trampoline. The yellow righting line is tied to the dolphin striker and threaded through the center lacing for storage and easy access.
