It is currently Wed Nov 22, 2017 8:58 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Wed Apr 25, 2012 1:54 pm
It is interesting to read all of the threads on this issue over the last 3 years. Although more common in AI's, it has also been reported in Outbacks and Revos with the left side being more common. Although drum issues caused some of the problems most were not. Although roadrunners fix addresses the symptom, it does not fix the problem which is what Matt says that the drum is in contact with the locking mechanism and the movement and friction walks the cam open. The underlying cause is the there is a small difference in height between the right and left CNG. The CNG which is higher fully locks and stops the downward movement of the drive. The lower CNG locks but the drum is sitting too high. The only way to solve the problem is to raise the CNG with washers or shim. Filing plastic as mentioned earlier will only fix the problem if the drive hitting the hull is what is stopping the downward movement. On my adventure, the drive sits about 1/4" above the shelf when engaged as I suspect in most cases. The root cause is that CNG has a very low tolerance for vertical mounting differences. Rotomolded kayaks can be quite variable and so every once in a while, this happens. AI are probably more susceptible because of the torsional stress on the hull and the left side being affected more probably is a by product of the rotomolding process. Just my opinion of course and will test the fix this weekend.
PostPosted: Thu Apr 26, 2012 6:43 am
Hi Guys,
Thanks for the input Matt & GB2, I understand all that you are explaining.
On my 2011 Revo 13, I have checked out the fit of the mirage drive, it has a nice fit, with a slight fore & aft rock to it. I have removed the plastic covers on the C&G to ensure that it is fully engaged.
I haven't taken notice of the height of the C&G units, but I have discounted this before because this problem has just recently become a problem.
The previous 12 months no problems at all.
It seems like a wear issue, but visually all seems good.
I will be measuring the main shaft length soon to see if it has moved, but once again, the C&G units are fully closing.
Cheers,
Montedane.
PostPosted: Thu Apr 26, 2012 10:48 pm
montedane wrote:
...this problem has just recently become a problem.
Make sure your C&Gs are operating smoothly (flipping back and forth freely, not hanging up), lube with penetrating oil if necessary. Check your drumshaft to see that it is centered. 8)
PostPosted: Mon May 14, 2012 8:32 am
Raising the left CNG with one washer and grinding the bottom of the CNG well where the drum sits by 1mm corrected the problem. As it turns out my left CNG only had a 1mm clearance compared to the right which has 2-3mm so the left has to be mounted with a high degree of accuracy to lock properly. I suspect this is the reason the left CNG is more prone to releasing. If this a production issue, replacing the CNG will not correct the problem which is what my dealer suggested.
Users browsing this forum: No registered users and 5 guests
