It is currently Fri Jun 23, 2017 1:04 am
 Post subject: "Beaching" on concrete
PostPosted: Mon May 28, 2012 4:39 am
I'll be sailing alone, but the boat ramp I'd prefer to use on my lake has only a narrow (10 feet) concrete skirt next to it onto which I'd "beach" my Bravo. Just past the skirt is a rock wall dropping straight down into the water. After unloading the Bravo from the trailer, I'll have to leave the boat on the concrete skirt while I drive the trailer back off the ramp and park.
I'm worried about damage to the hulls while they're sitting on the concrete. The concrete in not very smooth, and unless I drag the boat all the way across the concrete and out of the water, the waves coming ashore will be rocking the boat while I park my vehicle.
I guess I could lay some kind of a cover (rubber? carpet?) over the concrete, and just hope it was still there after I got back from sailing.
Or I could lash some kind of cover to the bottom of the hulls that I could remove when I shoved off the shore.
Any suggestions?
PostPosted: Mon May 28, 2012 9:22 am
If the water is not too deep, why not make a little cheap (concrete block) anchor and anchor it out a little way while you are parking.
PostPosted: Mon May 28, 2012 10:02 am
Thanks again, Bahama Bravo.
The drop off on either side of the boat ramp at this location is pretty steep, but I'll take a closer look to see if I can anchor the boat anywhere nearby.
Do you know of any way I can reinforce the bottom edge of the hulls so that a few minutes rocking on the concrete wouldn't be too damaging? I don't mind particularly if the solution slows the boat down a little, so I'd consider even something like a thin strip of metal applied directly to the bottom edge of the hulls.
Is that feasible?
PostPosted: Mon May 28, 2012 10:14 am
You could try a skid plates like on Old Town canoes:
http://store.oldtowncanoe.com/products/ ... kid_Plates
They are not pretty, but they work.
Marc...
PostPosted: Mon May 28, 2012 11:20 am
Thanks Marc.
The skid plates may be just what I'm looking for. They're kinda expensive, but a lot cheaper than repairing the hull. As for looks, I'm not very pretty either.
