It is currently Wed Apr 24, 2024 1:41 am
 Post subject: Disassembly of crossbar
PostPosted: Tue Jul 11, 2006 7:17 am
Trying to replace my trampoline on 86 hobie 17. Is there a way to replace the rear without disassembling the crossbar? and if I have to take it apart, is there an easy way to do that?
thanks
PostPosted: Tue Jul 11, 2006 7:50 am
Authorized Hobie Dealer
you should be able to remover the tramp from the tramp removal slot in the center of the cross bar. Pull it out from the middle and both ends should start to slide out at the same time.
http://static.hobiecat.com/2010_archive/support/pdfs/H17Manual.pdf
The page with the updates on it also explains it.
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Tue Jul 11, 2006 9:22 am
Older boats don't have a removal slot. You're going to have to take the boat apart.
Invest in a "T" handle allen wrench. It's the 17 sailor's best friend.
Once you get it apart and take the tramp off, use a Dremel tool to cut a slot in the crossbar like the new boats.
PostPosted: Tue Jul 11, 2006 9:53 am
so with that philosophy, couldn't I use the dremel tool to cut a slot before i take the tramp off and then remove it? then i wouldn't have to take the boat apart.
PostPosted: Tue Jul 11, 2006 12:09 pm
You could, if you're careful and you don't care if you booger up your trampoline bolt rope a little.
It's a lot easier to do with the tramp off.
PostPosted: Tue Jul 11, 2006 2:04 pm
Thank you very much. You've been a great help.
I appreciate it.
