It is currently Fri Mar 24, 2017 2:24 am
 Post subject: Mirage drive and weeds
PostPosted: Fri Jun 01, 2012 3:49 am
Was wondering if anyone can share how the mirage drive does in weeds and grass? Does it get hung up? Anyone ever put in the Chasawitssa (pardon the spelling)?You'll know why I'm asking.
PostPosted: Fri Jun 01, 2012 4:51 am
Pull the drive and get to the edge of the grass or weeds then then begin fishing again. Even the flutter techinque of the drive will get weed build up on the fins... Good Luck
PostPosted: Fri Jun 01, 2012 7:23 am
I have never had any problems. But like the earlier post, pull up, clean, put back in go.
Steve Valerga Jr.
DV U.S.Army Airborne
1988-92
2012 Pro Angler
Take a kid fishing!
PostPosted: Fri Jun 01, 2012 9:10 am
I'll feel it bog down a little when I encounter a thick hydrilla area just under the surface, but usually if I just feather the drive until I'm clear, there's never an issue. I can't remember ever removing the drive to remove hydrilla or any weeds from it.
If I was planning to fish in an area with a huge amount of growth to navigate through...I'd probably latch the drive with the fins against the hull and paddle/pole the area.
Just my thoughts...
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
2012 Pro Angler 14 (owned now by a good friend)
2013 Pro Angler 14 - Dune
2015 Pro Angler 14 - Papaya
PostPosted: Sat Jun 02, 2012 10:04 pm
If you're encountering anything like this...
it's time to pull the Drive. 8)
PostPosted: Sun Jun 03, 2012 1:04 pm
Sometimes, after you get through with a short stroke feathering motion, allowing the fins to hang straight down will simply allow the weeds to fall off.
PostPosted: Wed Jul 25, 2012 12:41 pm
I have had major problems in weeds fishing in the kelp on the west coast!
You will have to either fish the edge or get a nice spring start towards the kelp, pull the drive, MAKE SURE TO PULL THE RUDDER!!!, and then grab your paddle and have fun!
but make sure to pull your rudder or else you are going to stretch the cord in heavy weeds or kelp and you will have to retie the cord after every adventure.
