It is currently Thu Jan 18, 2018 11:14 am
PostPosted: Mon Jun 04, 2012 5:37 pm
So picked up an 81 H16 at the end of last season. Hulls in great condition and I've replaced practically everything on the boat minus sails, mainsheeting system, and trampoline. My mast currently has a slight bend in it and a good friend found a replacement comptip mast in excellent condition. However, I don't really know much about the comptips. I've read on here that some where retrofitted early on that were pretty lousy and they quickly changed the design. I believe the retrofitted ones were somewhat shorter than the aluminum masts as well. My concerns are this:
1) What are the advantages of having a comptip mast other than potentially saving myself from electrocution?
2) Will my current sails fit the comptip mast? or are they sized differently enough that I would need news sails.
3) Are there any performance advantages to the comptip mast?
4) I just replaced all of the standing rigging on my boat. Will the shrouds and forestays work appropriately with a comptip mast?
5) Are there any other major changes that I would need to make to my boat for this mast to work? I don't really have that much money to work with so basically I'm hoping that this mast will be my only purchase.
Thanks for the help gentlemen.
PostPosted: Mon Jun 04, 2012 7:52 pm
None, but see 3)
yes
3) Are there any performance advantages to the comptip mast? "They" say, the comp tip will help spill off more air in a big blow. The Hobie 16 is overpowered and you're looking for ways to dump power in heavy wind, but the difference will be negligible for recreational sailing
yes
no
save your money for other stuff. sail the boat, enjoy and then make a decision of what your priorities are for your hard earned sailing dollars. There's no law that says you cant sail a Hobie with a solid mast, just be very careful where you launch and sail. If you end up at a regatta, you're allowed one exemption (one regatta) to the HCANA comp-tip rule. If you have fun, and want to come back to race again, asking the folks at the regatta is probably a good way to find a used comp-tip mast.
Sheet In...Max Out
www.fleet297.org
PostPosted: Mon Jun 04, 2012 8:08 pm
By saying that I don't have the money I was merely implying that I don't have the money for new sails if they were necessary. My friend who I am getting the mast from is basically giving it to me as he is a sponsored racer and gets all kinds of free stuff. A good friend to have if your into hobies. I paying next to nothing for the mast. I just wasnt sure about the other stuff and my buddy is out of the country, thus, unable to answer the questions for me. However, thank you very much for your thorough responses. I will be looking forward to getting out with a new "straight" mast lol.
PostPosted: Tue Jun 05, 2012 5:34 am
The main disadvantage of an all aluminum mast is that you can no longer get a replacement masthead sheave. Since the aluminum mast is at least 30 years old the sheaves are pretty brittle.
PostPosted: Tue Jun 05, 2012 6:42 am
I would choose a straight comptip mast over a bent aluminum mast any day of the week. The only exceptions being one of the first generation comptip masts (the one that installs about a 6 or 10 inches above the hounds and is held in by a large phillips head screw on each side of the mast), or a comptip that is totally sun fried.
For recreational sailing, you will not notice any difference between a comptip mast and an all-aluminum mast, especially on a 30 year old boat.
PostPosted: Tue Jun 05, 2012 7:27 am
FYI - I believe you will need more main halyard line with the comptip.
http://www.hcana.hobieclass.com/site/ho ... engths.htm
Jonathan
'85 H16 __/) 87468 Tidal Wave
PostPosted: Tue Jun 05, 2012 9:08 am
You will need an entirely different main halyard assembly with the comptip mast. The length of the wire section is much shorter when using the comptip.
Users browsing this forum: Majestic-12 [Bot] and 2 guests
