It is currently Tue Jun 27, 2017 12:42 pm
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: My rigged 2012 PA 14
PostPosted: Fri Jun 08, 2012 6:16 pm
Ok so the lowrance elite 5 is gone. The good news is, im picking up my Lowrance HDS5 gen2 nautic insight tomorrow. Not sure if i will get the structure scan right away or wait a few weeks. Im still tossing around mounting ideas/options.
PostPosted: Fri Jun 08, 2012 9:06 pm
so much for the bird huh?
I think the structurescan thingie is a whole seperate transducer?
2011 Hobie Pro Angler - Papaya
2012 Hobie Tandem Island - Papaya
PostPosted: Sat Jun 09, 2012 5:20 am
Yepp. I got a deal i couldnt resist.
PostPosted: Sat Jun 09, 2012 6:18 pm
Any pics of your tranducer setup?
Nice job on all that work.
Hobie Pro Angler
PostPosted: Sat Jun 09, 2012 10:00 pm
Ok so i got the lowrance hds5 gen2 today and all i can say is WOW!! just playing with the features and settings has me really excited. I will share my install pics as i go.
Tonights progress was mounting the unit and running/securing the power cable and test for operation.
First i started off with a female scotty flush deck mount and a scotty swivel base. Flush mount was already installed and i riveted the cradle to the scotty swivel base.
PostPosted: Sat Jun 09, 2012 10:12 pm
Next step was to mount the head unit and run power wires. I will have more pics as i go tomorrow.
Test run before routing power cables
The routed power wire with fuse block. Nice and clean. Fastened up high just in case of leakage.
Thats all i have for tonight. I will have more pics of the transducer installation as well as the bulkhead fittings installation tomorrow...
PostPosted: Sun Jun 10, 2012 2:23 am
wow, can't wait to see it!
thats after he uses it tarpon fishing today!
(and now, I'm gonna call u and make sure yer up! Mr., I only wanna sleep 4 hours or less)
PostPosted: Sun Jun 10, 2012 9:17 am
I didnt even hear my phone ring. Woke up at 930 and saw that everyone blew up my phone. I needed the sleep anyway. Work has been running me hard.
Anyway, transducer cable has been ran and all i have left is to install the transducer in the hull. I will use marine goop. I have the foam pad that i got in my hobie fish finder installatiin kit but the new transducer is much larger so it will just be gooped by itself to the hull.
More pics to come...
PostPosted: Sun Jun 10, 2012 10:31 am
Ok heres some updates. First the 1" hole that was previously drilled for the wiring had to be trimmed so that the oversized connectors could both fit through.
Its a tight fit but thats great so that water doesnt have a chance to get in easily
Next step is installing the transducer. I prepped the area with sandpaper as well as the transducer, layed down a nice puddle of marine goop and positioned the transducer with tape so that it wont move.
PostPosted: Sun Jun 10, 2012 10:33 am
Now to air dry....
PostPosted: Mon Jun 11, 2012 5:37 am
Question. Where do you buy the grommets for the wires coming out the side and up into the starboard? Just bought an mark 4 and thought they came with it but didn't. Tried home depot but the inner diameter is too big on the rubber grommets and will let water in.
2012 Hobie Pro Angler 14
2009 Hobie Adventure Island
2011 Hobie Adventure Island
PostPosted: Mon Jun 11, 2012 8:44 am
I got mine (the same as Glenn's) from our local hobie dealer, they had em.
PostPosted: Mon Jun 11, 2012 11:22 am
Mine was included in the hobie fish finder installation kit. Ill call the store today and see if they know who makes it. The store is called tackle shack.
PostPosted: Mon Jun 11, 2012 4:38 pm
Ok install is complete. Wires are secured. However i had some problems with the marine goop. At the 20 hour mark there was no bubbles. When i got home from work around the 30 hour mark there was an abundance of air bubbles throughout. I slowly installed the transducer from the backside slowly tilting forward to ensure no air bubbles. Not sure what happened. Something in the curing process??? Not sure. Heres a couple pics. One of the install and one of the bubbles.
PostPosted: Mon Jun 11, 2012 5:49 pm
I am also interested in the lumbar support. I tried to find it without any luck. Where did you get it from?
-2012 Dune PA14- 2011 Jackson Coosa-
" Its all fun and games until somebody gets hurt, then its hilarious"
Users browsing this forum: taz1967 and 4 guests
