It is currently Sun Aug 20, 2017 10:17 am
PostPosted: Wed Jun 13, 2012 5:44 am
Hi all,
When I got my boat the front trap shock cord was shot, and as I have now learned - routed incorrectly. It just ran straight thru the front crossbar - an 8ft length; in one end out the other. Ive searched the forums here, and found some info but its still not clear.
* do I need 2 16ft. lenghts of shock cord for the front?
* does it start and return to the same side? run thru block on other end?
* do i need to drill the rivets and remove the end cap to route? try a snake?
Thanks for help.
JDM
PostPosted: Wed Jun 13, 2012 9:08 am
Yes, Yes, & Yes.
Drill out the rivets that hold the end cap in place and you will see how the system is routed. There is a single pulley and a single tie-off point on each end of the crossbar. You tie off, pass the bungee through the crossbar to the pulley on the opposite side, and then back out through the end cap on the side where you started. Repeat for both sides.
The other option is to add another grommet to the tramp and lead the crew's trap line to the shroud in the same way that it's done for the skipper.
PostPosted: Wed Jun 13, 2012 10:36 am
Thanks - big help!
one question; should I drill out and remove the end caps on both sides? or just one?
Jim
PostPosted: Wed Jun 13, 2012 11:15 am
You will need access to both end caps.
