It is currently Sun Jan 21, 2018 12:59 pm
PostPosted: Tue Jun 12, 2012 8:49 pm
I'm about to purchase an oasis for lake & river fishing. I can see the merits of the anchor trolley system in a lake where wind will determine boat position & the best place to anchor from the oasis. However, when river fishing in a moderate current I would like to set up an anchor system to have it released from the rear point of the kayak. I'm used to an anchor system with a release & pulley system so I don't have to actually pick up the anchor & throw it into the water. Similar to an anchor system in a river dory. (for flyfishing)..... Has anyone set something like this up on a hobie??
PostPosted: Wed Jun 13, 2012 10:26 am
No but you can use the scotty anchor rig off the back and use rope at the cockpit with the same clasp as the rudder uses. Good Idea :D
Steve Valerga Jr.
DV U.S.Army Airborne
1988-92
2012 Pro Angler
Take a kid fishing!
PostPosted: Wed Jun 13, 2012 2:11 pm
I've never bothered with any sort of trolley. Just bore a small hole fore and aft and insert and thru-bolt a stainless steel eye-bolt. Fasten a ClamCleat Jr. on the gunwale (I mount one on starboard/forward and one on port/rearward) and run a 3/16th inch starter cord from cleat to eye-bolt. Now you can anchor (one-handed) either from the bow or stern at a second's notice.
PostPosted: Thu Jun 14, 2012 6:25 am
Thank you for your ideas folks. I like the scotty mounts. Seems like it would be easy to use for a multitude of mounts..... rod holder as well as anchor system. I didn't see a weight rating on the mounts but hoping for 5lbs for the anchor. In most rivers I think I'll need at least that much. I also saw the http://www.scotty.com/fishing-gear-equi ... apease.htm , which I think I'd like to use in conjunction with the scotty anchor lock, or maybe a different lock. I like being able to extend the anchor past the side of the yak. Don't want it bumping around too much. Anyone use the trapease??
PostPosted: Fri Jun 15, 2012 2:52 pm
I have an Outback, and the scauper holes in the rear allow me use a 1/2" PVC pipe with a T fitting glued to the top($3.00 total). If the current is slow to moderate it will hold you facing down stream. Works best with the rudder up. If you put a little weight in the pipe it holds very well even in a faster riffle. My freind has a Pro angler and it holds that exceptionally. The bottom content definately plays a part in it, harder bottom with a faster current they aren't as effective. I have two on board, that helps me from swaying. If it's less than 5' deep I'd rather use the poles than the trolly system.
Pete
The tug is the drug!
Users browsing this forum: No registered users and 5 guests
