It is currently Sun Mar 26, 2017 2:25 pm
 Post subject: H14 Conversion to H14t
PostPosted: Mon Jul 16, 2012 5:01 pm
Would you be able to to have a trap, and and jib on a H14 with out a dolphin striker?
PostPosted: Mon Jul 16, 2012 5:13 pm
You could . . .
But you'd have a broken boat in very short order.
The dolphin striker turns the simple beam of the front crossbar into a truss member, capable of carrying the additional mast compression created by the jib and trapeze.
PostPosted: Tue Jul 17, 2012 12:31 am
Never mind that i just found out that she has cancer, soft spots in the front of both pontoons. You wouldn't happen to know if you can fix the issue would you? Because I have got a series of 5 regattas coming up and i have paid the entry fees already.
PostPosted: Tue Jul 17, 2012 7:31 am
Try this link..
viewtopic.php?f=18&t=1156
It talks a little about soft spots/delam
1972 Hobiecat 14
PostPosted: Tue Jul 17, 2012 1:29 pm
Thank you this helps a lot, I have 2 Patches foreward of the cross beams on both hulls, some in the middle of them and a little on the side of one. I might just enter in a laser full fig seeing this may take time to fix. Thanks again for your advice. :)
PostPosted: Wed Jul 18, 2012 6:29 am
Git rot will fix soft spots in a heartbeat - just checkout the posts, tape it, drill it, fill it and(when dry) sail it
1985 Prindle 16
