It is currently Mon Jun 26, 2017 1:22 pm
PostPosted: Tue Jul 24, 2012 5:01 am
I need to know what part to buy. I have 2 panfish mounts. One is the short one, and the other is the long pole mount. Both are made to mount to the gear track. What I am looking for is a way to mount the panfish to the "sail hole" in the front of the cockpit area. Not sure what the hole is called. It has a rubber cap on it and the pics in the catalogue show the sail here.
I don't want to change the way the pole mounts, I just want to add a mount to that hole that is the same as the geartrack slot.
Any ideas? Thanks
Jeff
2012 PA14 (PA14)
'85 Land Cruiser FJ60
Custom PA14 / Recreation Stuff trailer
Old Outback - SOLD
It's called "Fishing" for a reason...Otherwise, it would be called "Catching"
PostPosted: Tue Jul 24, 2012 2:48 pm
Jeff,
You may be able to use a Ram wedge 1.5" part # 72023015 ($14.95)
Gene
PostPosted: Tue Jul 24, 2012 4:46 pm
Its called the "mast" hole. I did just that, mounted a RAM wedge mount in the mast hole then two dog bones then the GoPro mount. Had to use a bungee cord from the front carry handle to the middle of the dog bones because the entire assembly bounced around too much. I also used the 1.5" balls instead of the 1" balls.
PostPosted: Tue Jul 24, 2012 8:42 pm
Is that a ram part number or a Hobie pat number? Thanks
2012 PA14 (PA14)
Old Outback - SOLD
PostPosted: Wed Jul 25, 2012 5:34 am
Hobie
Users browsing this forum: AKRuss and 6 guests
