It is currently Fri Nov 24, 2017 10:45 am
PostPosted: Sat Aug 04, 2012 6:53 pm
ANY ONE HAVE THE INSTRUCTIONS ON REPLACING THE CENTERBOARD LINES ON HOBIE 21SE
PostPosted: Mon Aug 06, 2012 8:15 am
Hobie Tech / Moderator
Instructions are on our support page at the top of this page - link: http://www.hobiecat.com/support/products/hobie-21/
Jacques Bernier
PostPosted: Mon Aug 06, 2012 12:51 pm
You will be using that old line to pull the new one in place while the boat sits on the trailer. :wink:
It is really petty easy, just lower your centerboards all the down to expose where the knot on the centerboard and pull it out of it's small pocket and cut off the knot.
Wrap some electrical tape around that line just above where the knot was that and burn/melt the end you cut so it doesn't fray and poke a hole through it with a awl so you can fasten a paper clip formed to look like a "S" through that awl hole.
Do the same thing to your new line and tape the paper clip so it won't open on you while you pull it up through the deck fitting and put and old handle on the new line and tie everything off.
Now go sailing.... :D
Bill 404 21SE
PostPosted: Sun Aug 12, 2012 8:13 am
just did it last week on the dock in 5' of water
Drop the centerboard all the way down put new rope thru the hole
pull out the center of the rope and cut this off about 2" back leave the rope cover in good shape and burn the end
this lets the rope go into the hole in the centerboard pretty easily needle nose pliers are great to have cut off the 2" of line cover and burn end tie a knot pull tight and stuff into the centerboard
