It is currently Thu Nov 23, 2017 1:24 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: Gear Trac rail mount
PostPosted: Mon Jan 02, 2012 1:58 pm
I also received my rail clamp prototypes from Luther over at YakAttack and mounted up my new 16" GearTracks this past weekend.
First impressions are pretty high considering the mounts Luther sent are prototypes. I received 2 mounts per rail, but with the 16" I think 3 would be better to ensure that they stay put under the torque of a rod during trolling. I have yet to test them out on the water. However, the production mounts may be more robust than the prototypes so I will just have to wait and see.
The tracks themselves are HEAVY DUTY! They look and feel very high quality for an aluminum alloy extrusion. I like the 16" track because they give you plenty of real estate to mount to. I could run two of the scotty set ups on both rails if I were cat fishing or bottom fishing. The other possibility is I could move my fish finder on the rail as well if I needed to for better viewing.
I mounted them as far forward as possible not to hang over the rail but to ensure clearance for the rudder control. I also purchased the Mighty Mount Scotty holder set up so that I could mount my Scotty Quick Draw rod holders to tracks.
Sorry about the picture quality, the light wasn't the best to take pictures with my iphone.
RedWolf3773
2011 Hobie Pro Angler
Rigged for War!
PostPosted: Tue Jan 03, 2012 2:15 pm
Looks good Redwolf!
The prototypes are milled from Starboard, which is a pretty flimsy plastic that's easy to machine and great to make prototypes from. But the production brackets will be injection molded Nylon 6/6, which is MUCH stronger. They will also have stainless steel nuts instead of threaded plastic, so you can tighten them up much tighter without stripping the threads.
Thanks!
PostPosted: Mon Aug 13, 2012 10:46 am
I like that STS!
Rob Milam
2014 Pro Staff
Hobie Cat * Dobyns Rods * Power-Pole * Smith Optics * Super Nova Fishing Lights * Xcite Baits * Werner Paddles * Lowrance
