It is currently Wed Dec 13, 2017 3:46 pm
PostPosted: Fri Aug 31, 2012 2:33 pm
Hi,
Has anyone attached the Hobie trailer cradles to Thule Aero bars using the T slot? If you have what length of screw bolt do you need? If not available then what is the best way to attach?
Cheers
Silky
PostPosted: Fri Aug 31, 2012 5:19 pm
Well, I thought about going this route and decided against it.
Personally, I would use a carriage bolt through a set of square bars for this application, or add clamp-on Thule saddles (which I did).
The thin, slide-in T-bolts are made for lighter equipment mounts, like bikes or snowboards. The longer you make these, the less you will be able to trust them.
I get the impression that Rhino Rack's channel system is much more robust and maybe up to the job. Our Aussie friends may be able to comment on this.
Users browsing this forum: Yahoo [Bot] and 4 guests
