It is currently Wed Jun 28, 2017 9:23 pm
 Post subject: Bridle Lengths
PostPosted: Wed Sep 05, 2012 10:11 am
Are the new one shorter then pre 2006?
 Post subject: Re: Bridle Lengths
PostPosted: Wed Sep 05, 2012 2:06 pm
Word I heard were that they were longer (= jib higher, more mast rake). Class rules only specify minimum length - 44" pin to pin.
PostPosted: Wed Sep 05, 2012 2:21 pm
Current length is 3' 8.5".
PostPosted: Fri Sep 07, 2012 2:19 am
Is that not too long ?
PostPosted: Fri Sep 27, 2013 8:29 am
I have been trying to find answers about the bridle length. Class rules say a minimum of 44 inches.
Is it better to have a longer bridle or a shorter bridle? I understand that a shorter bridle will get the jib lower, but does bridle length have any relationship to the size of the slot at the top of the jib? :?: :?
2011 H16... Have a Hobie Day!
1983 H14 Turbo...
PostPosted: Fri Sep 27, 2013 10:27 am
That is 44 1/2", your fine
PostPosted: Fri Sep 27, 2013 10:28 am
You have a 7-10 hole adjuster plate up there to raise and lower the jib. 1" difference not gonna matter.
PostPosted: Mon Sep 30, 2013 7:56 am
It seems like 1" makes a lot of difference. I already have the 10 hole adjuster turned upside down and put the jib in as low as as I can. But even with this setup I can't ever get block to block on the jib with any tension in the rig.
Shortening the bridal seems like it help me with this problem?
Thoughts???
Have a Hobie Day!
Sent from Tapatalk
1983 H14 Turbo...
