It is currently Thu Mar 23, 2017 6:30 am
 Post subject: beaching in surf
PostPosted: Sun Sep 30, 2012 4:17 pm
I sail in the Gulf, off the beach. When I return to the beach, incoming waves impact the rudders and have 'dented' the black plastic where the rudders strike the gudeons.
It takes a minute or two to dismount and either push the boat out of the waves from the stern or pull the boat out using the front cross bar or the forestays.
I don't see any way out of this, but thought I'd ask if anyone else has a better method/solution.
I've started disconnecting one end of the tiller which allows each rudder to move separately in the wave action.
thanx,
 Post subject: Re: beaching in surf
PostPosted: Sun Sep 30, 2012 4:46 pm
Why not just hang on to the tiller and ride all the way onto the beach instead of stopping short? It's tough on the bottoms but getting a wave across the transom can break all kinds of things (including body parts). Rotomolded Waves are tough boats so it shouldn't be a issue.
If you are going to sail in the surf dings, scratches, and broken stuff come with the territory.
Garrett
94' H16 - 114050
https://www.facebook.com/groups/423463424425838/
PostPosted: Tue Oct 02, 2012 7:47 pm
I also sail on the gulf, Surfside Texas. I come in at a 90% angle to the beach all the way through the surf zone, keeping watch on the waves coming in and keeping the weight to the back of the tramp. I stay and keep the "super cargo" on the boat until it is safe to get off usually when the hull drags bottom, and lift the rudders also when they hit the beach, which also may need lowering between sand bars. 8)
PostPosted: Wed Oct 03, 2012 7:11 pm
Same here. I often come in through small wind waves (maybe 0.5m) and come in perpendicular to the beach, until the rudders kick up. In a good wind I can sail right up onto the sand. That's what sailing a beach cat is all about! :D
stuart
2011 Hobie Wave with jib kit & mainsheet traveller
PostPosted: Wed Mar 13, 2013 8:21 am
Daytona Beach, same thing. Bring the cat in at 90 degrees to the beach, ride in, rudders kick up, I still keep going till I hit the sand. That is 1/2 the fun of the day right there. Often I'll turn right around and do it again a few times. I never could surf. :mrgreen:
PostPosted: Sat Mar 16, 2013 10:37 am
If you do it like this you only scrape one hull!
Jack Woehrle
Wave #100
H20 #287 "Tallahassee Lassie" (down in FLA)
PostPosted: Sat Mar 16, 2013 11:05 am
Only issue is you'll scrape up that awesome paint job!
Zach
PostPosted: Sat Mar 16, 2013 1:40 pm
Yup!
Jack Woehrle
Wave #100
