It is currently Thu Jun 29, 2017 10:02 am
 Post subject: Mirage drive repair?
PostPosted: Tue Dec 04, 2012 5:58 pm
Does anyone know of a way to fix this without replacing the entire chain assembly? Is there anywhere that sells just the cable+linkage? I was hoping to avoid paying $40 for an entire chain assembly
Hobie Revo13
www.Facerbook.com/TeamDizzyLizzy
www.PensacolaFishingForum.com
 Post subject: Re: Mirage drive repair?
PostPosted: Thu Dec 06, 2012 3:20 pm
That is a special part and a very specific length. I don't think it is repairable.
PostPosted: Thu Dec 06, 2012 3:42 pm
Matt should know, but for me, I would not want anything but orginal parts. If a bad repair takes place and then other parts might start wearing out quicker. Then you will be looking at $500 total replacement instead of the $40 for the easy fix. Good Luck
PostPosted: Fri Dec 14, 2012 9:03 pm
Bo-Keifus,
How did you break it? Should I be concerned about breaking mine (although I already carry a spare)?
PostPosted: Mon Dec 17, 2012 10:55 am
That is a fatigue failure typically. We designed the drums to limit the flex of the cable as it enters the rolled end fitting, but the process or roller swedging the fitting and the stiff to flex transition of the area is a stress point that sees failures from time to time.
PostPosted: Fri May 17, 2013 5:44 am
A friend of mine had the same problem. Although we use WD-40, there was rust on the cable.
With other MirgeDrive sets we made little improvements:
Wrench 11
Rust converter
Marine grease & Gaine thermoretractable 7mm
