It is currently Fri Jul 21, 2017 4:46 pm
 Post subject: Cleaning Elite
PostPosted: Mon Dec 24, 2012 10:14 pm
How do you guys clean your fishfinder/graph after a day on the water with lots of salt water gettin all over it?
 Post subject: Re: Cleaning Elite
PostPosted: Mon Dec 24, 2012 11:07 pm
I just wipe it down with a rag with fresh water lightly then dry with towel.
I live on the coast and wash all my gear on the kayak with a garden hose. Mirage Drive, poles anything metal. then stand to dry or dry off with a towel.
Hope this helps
"The craft is a foot bigger at port and shrinks a foot at sea."
BentRodyakker
PA14
Rockaway Beach
Oregon
PostPosted: Mon Dec 24, 2012 11:14 pm
Hobie Team Member
hi, I use warm soapy water if available, dry with a microfiber cloth. while fishing, if needed, i rinse it off with my drinking water.
Fishing is not a matter of life or death... It's much more important than that!
PostPosted: Tue Dec 25, 2012 12:47 am
Technically how waterproof are lowrance elite fishfinders?
PostPosted: Tue Dec 25, 2012 6:03 pm
technically, they are supposed to be waterproof, but i dont think they list any of the units with a JIS rating. i've had maybe a dozen lowrance units over the last 8 or 9 years, and with only an exception with a screen fogging here and there, i've done everything but submerge them. if you are concerned with spraying them off, dont worry. unless you you a pressure washer i dont think you will ever have an issue.
cheers.
drew
Cathedra Mea, Regulae Meae.
PostPosted: Mon Jun 01, 2015 12:03 pm
I do wipe with soapy water but the main problem is the contacts. those will quickly corrode and not create a circuit. I use a reel oil on each one blow them off and air dry. I use a small wire to work the oil into the holes where the pins go and then clean the pins too. Then I check the connection to make sure everything is OK. That salt water can be rough. I think there's an oil which is made for contacts which is conductive which you may want.
Users browsing this forum: No registered users and 16 guests
