It is currently Tue Jan 16, 2018 4:46 pm
 Post subject: Through hull grommet
PostPosted: Fri Dec 28, 2012 11:13 pm
Hi all.
I am just installing my new Lowrance 4x fish finder.
On one of the Honie Tech videos, it show a two piece scre in grommet that is screwed into the deck.
Does anyone know what this is called or where to get it?
This is the video:
http://www.youtube.com/watch?v=St68N3bxFvU
 Post subject: Re: Through hull grommet
PostPosted: Sat Dec 29, 2012 8:26 pm
you can get one from an marine supply place, but Hobie just came out with there own that they use on the pro anglers. Its called the hobie through hull wiring kit and comes in a 2 pack, for $12.99. Also the hobie ones are way better than any of the boat fittings we have been using for years, they seal up a lot better. if you look in the back of the fall 2012 parts catalog you'll find it.
PostPosted: Wed Jan 02, 2013 5:46 pm
72025006 WIRE CAP, THRU BULKHEAD
86505621 HOBIE THRU HULL WIRING KIT
Instructions:http://static.hobiecat.com/item_attachments/86505621z2.pdf
PostPosted: Thu Jan 03, 2013 8:01 pm
thanks to both of you.
Ideally, I want to be able to transfer the fish finder and transducer between two kayaks, as I use the other kayak when I am taking out a novice. I always get the novice to use the Revolution.
Will the new part allow me to transfer it, or will I need to have a coupling lead of some sort under deck.
thanks
Tony
PostPosted: Fri Jan 04, 2013 10:11 am
Both require dis assembly of the through hull seal / grommet to pull wires out.
PostPosted: Sat Jan 05, 2013 12:26 am
thanks
Tony
Tony I have installed my humminbird to be transferable between the TI and revo. You will see some pics in the pimp my revo post.
Cc
PostPosted: Mon Jan 07, 2013 2:51 pm
I installed one of these wire caps on the left gunnel just a few inches ahead of the fish finder. Its a pretty elegant through-hull wiring solution, and only took 10 minutes to install.
