It is currently Mon Jan 22, 2018 12:24 am
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Fri Mar 23, 2012 6:17 am
Nice job Razoyak!
That looks very nice!
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Ambassador
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Sun Jan 06, 2013 7:23 am
Hi SkiPro and Razoryak,
I'm trying to set up my trailer similar to what you did on yours. Can you tell me how far apart (front to back) are the brackets for the PVC pipes? Mine may be closer than yours making the PVC have less flex and not cradling the boat all that well. i'm thinking of changing to 2" or maybe 3" pipe to see if that helps, but just wanted to check on your setup before i go changing things.
Thanks!
PostPosted: Sat Jan 19, 2013 5:31 pm
What ended up being the total lenght of the pvc for you guys?
Hobie Pro Angler
PostPosted: Thu Jan 24, 2013 11:15 am
I am about to order a PA12 and an Outback (both 2013) and plan on using a recently purchased small trailer of sufficient size to carry both of them. Your use of PVC tubing for the PA is a great idea.... But will it work for the Outback?
PA 12
Rev 13
Laser
Maverick HPX 17V
