It is currently Fri Jun 05, 2020 10:59 pm
Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
 Post subject: Re: PA Seat Modification
PostPosted: Thu Mar 14, 2013 12:00 pm
Here is a nice selection of seat slides I found at www.PartsPak.com. I have used these guys for years for other marine parts.
http://partspak.com/productcart/pc/show ... der=0&SKU=
PostPosted: Thu Mar 14, 2013 10:09 pm
Hobie Team Member
Joey,
Thanks for the post with great PIC's. I just received my seat slide and plan to install it soon.
Thanks again
Tim
Fishing is not a matter of life or death... It's much more important than that!
PostPosted: Sat Mar 16, 2013 11:08 pm
I have a 2 step solution.
Step 1: Toss Seatasaurus Rex to the tip, or donate to local croquet club. (Cause that is what it looks like it came from)
Step 2: Insert Surf to Summit Expedition Seat.
http://www.surftosummit.com/gts-expedit ... 99_294_325
Besides the "Gatsby" look of the original seat, it weighs a ton, and is a dangerous item. Possibly the most dangerously, over engineered, under thought (besides our friend Rodney Rudder) item on the thing. Why? because as you lean to counter the roll, ones butt simple falls away and increases the moment of rolling.
Take a look at the GTS seat Hobie geeks. THIS is design.
PostPosted: Wed Apr 10, 2013 3:46 pm
I went with the bass pro sliding seat. Read comments here and decided my fingers were too big to install it as was. Removed the 2 bolts on the lock arm, and slid the slide completely off. Then mounted it to seat, put slide plate back together and remounted the lock arm and bolts. Easy on the fingers and 20 minutes, start to finish. Hope this helps.
2012 PA 14 dune
2012 PA14 Dune
Life, Liberty and the pursuit of fish!
PostPosted: Thu Apr 11, 2013 1:46 pm
Ordered the seat slide and it will be my first mod to the PA when I pick it up this weekend. Thanks again for the helpful advice on this board.
Users browsing this forum: Google [Bot] and 0 guests
