It is currently Tue Dec 12, 2017 8:29 pm
PostPosted: Thu Mar 28, 2013 8:37 pm
I'm new on the block here, but haven't discovered a Search function if there is one?
Forgive me if this has been covered somewhere else, but I will have ordered a set of ST fins for my Outback. I understand from the catalog copy that they are adjustable to accommodate either speed or low-end torque? What adjustment(s) are made to fine-tune the fins?
Thanks!
PostPosted: Fri Mar 29, 2013 1:35 pm
Steve - there is no adjustment to change power other than changing fins. You can adjust length of leg settings. Best bet is to get out on the water and play around.
PostPosted: Fri Mar 29, 2013 2:25 pm
Search link is located in upper right corner of page, just above today's date.
SailHo Kentucky
PostPosted: Fri Mar 29, 2013 4:57 pm
I think he's referring to the brass adjustment screw at the top of the fins, to adjust fin tension...here's a link:
viewtopic.php?t=10176&highlight=turbofin+adjustment+clew
PostPosted: Fri Mar 29, 2013 8:29 pm
Thanks gents!
Yep, I finally "found" the Search button, don't know why that was hiding from me.
And yes, I was inquiring about the brass tension screw on the ST fins, but the link plus further search seem to answer my questions. I was just hoping to avoid lots of trial-and-error on the water.
I appreciate your willingness to share experiences.
I've been peddling my Outback for several years pursuing monster trout on my local lakes, but only recently decided to see what I was missing from the Hobie Forum. Glad I finally found my way.
Appreciate it!
