It is currently Tue Jan 23, 2018 6:52 pm
PostPosted: Tue Apr 09, 2013 9:14 pm
This is a modification someone made in a desperate situation I suppose. I found this on a cat I was taking apart last week.
Where he found this plug I will never know!
Show us what you do to get by.
H18 '85
H18 '89 "Knotty Passion"
H20 '96 "20/20 Vision"
Fleet 259 Central Coast California
PostPosted: Wed Apr 10, 2013 8:27 am
How about some duct taped hulls:
myself and some friends after a sail across the pamlico sound
'79 H16 "Carmelita"
PostPosted: Wed Apr 10, 2013 10:11 am
I used a cork as a hull plug for a couple days while waiting for a proper replacement. The local hardware store had a bunch of different sizes of corks.
On a 16 that I used every day for two weeks and kept on the lake shore in front of the house, I quickly tired of trying to unscrew the shackle pin on jib blocks at the tack by hand (painfully and unsuccessfully) or fumbling for pliers, so the shackle was replaced with a carabiner. I kept the carabiner for three more seasons and never had a problem.
Realized I lost a hull cover for an 18 just before shoving off the beach for a weekend race. Cork Guy came to the rescue with a butt-load of duct tape to cover it, and the hull was dry after two days of racing.
PostPosted: Thu Apr 11, 2013 2:49 pm
H17Sport with integrated track using H16 integrated track cars with modified vertical (+15 degrees) and horizontal (rotated in) cam-cleat position and a custom travler set-up. Works great.
http://www.thebeachcats.com/pictures/?g2_itemId=61752&g2_imageViewsIndex=1
:wink:
PostPosted: Mon Apr 15, 2013 5:55 am
I'm not sure which was more scary, the duct taped hulls or the poor people being consumed by a giant hotdog shadow creature.
PostPosted: Mon Apr 15, 2013 9:54 am
:lol:
1980 H16
PostPosted: Tue Apr 16, 2013 1:37 pm
I take it you've never been attacked by flying hotdog shadow creatures. they're much worse than duct taped hulls.
'79 H16 "Carmelita"
PostPosted: Wed May 08, 2013 5:40 pm
How about a Hobie frame that was just loose enough to let go of the tramp whenever it was tightened, fixed with some bolts:
It worked...now it needs to be done to the rest of the crossbar on that boat...
'79 H16 "Carmelita"
PostPosted: Wed May 08, 2013 5:47 pm
Were you putting a factory hobie tramp in that needed that treatment? Or aftermarket. Seems some of the aftermarket use a smaller "bolt rope" which is just stupid imho.
1980 H16
PostPosted: Wed May 08, 2013 7:39 pm
Here's my latest spinnaker, spin-brella or umbrellaker (whatever you want to call it):
It really works pretty well! It noticeably improves downwind speed in light air.
What - Me Worry?
2006 Hobie Wave 7358
"Ish Kabibble"
PostPosted: Thu May 09, 2013 4:35 pm
yep, one of those single big piece mesh (not including the small rear piece) tramps that just gets laced down the side and back.
'79 H16 "Carmelita"
PostPosted: Fri May 10, 2013 8:35 am
A Row-B-Cat... What to do with a soft spotted boat.... cut 24 inches out of the width.... drill some oar locks
it goes pretty fast... and straight... and will take stormy weather...
8)
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
cron
