It is currently Thu Jan 18, 2018 11:50 pm
PostPosted: Tue Jun 12, 2012 11:09 am
I just ordered a TI and I am a para-T4 ( no trunk or leg control) I am looking for ideas to make the pedal system into a hand crank system. I would like to bring the hand crank back so i don't have to bend over so much. I have sailed for over 25 years/ monohulls-Nacra-cats-10 year george windsurfer.I have not sailed since my accident/ 8 years. I can get hand grips that will go were the pedals screw in to a standard pedal exerciser.
thanks
mike
PostPosted: Tue Jun 12, 2012 11:38 am
Maybe you could use some extension arms attached to the pedals with a hand grip within easy reach. Because the Hobie system is just push pull (mostly push) instead of rotary I think this would work. You cannot relocate the mirage drive because of how it is attached to the hull and leaning over is not very comfortable or efficient.
Good luck and let me know how this works as I have a friend in a similar situation that might go the same route (post some pictures). I know she kayaks with a paddle now.
PostPosted: Wed Jun 13, 2012 7:17 am
pipesail wrote:
... I would like to bring the hand crank back so i don't have to bend over so much. ...
I'm not an expert in this, but the mirage drive pedals are height adjustable, and the seat can be placed in one of two positions. Perhaps setting the pedals to something like setting #1 and if necessary, moving the seat to the forward position might work?
Like I said, I'm not an expert on what type of devices you have access to, but maybe the boat's built in adjustability can help a little bit.
Congrats on the new boat!!
PostPosted: Wed Jun 13, 2012 10:08 am
thanks, i have tried using the pedals with my hands on my brothers boat, it works ok but I need more time on the boat to see what might work the best.
PostPosted: Thu Jun 28, 2012 3:17 pm
Hobie Tech / Moderator
I ran accross this post from Roadrunner that may hive you some ideas.
http://www.hobiecat.com/forums/viewtopic.php?f=11&t=42174
A pedal extension seems like the way to go.
Brendan Castile
PostPosted: Fri Nov 09, 2012 2:30 pm
Good afternoon,
I was thinking something like this...
The only problem is there would need to be a drink holder between the legs, so the pivoting point (3 inch PVC) would have a place to fit...
If memory serves, one of the Hobies has a drink holder there doesn't it?
I just realized it doesn't have a drink holder, but there could be a type of base that could fit under the seat and protrude in front of the groin area to stablize the pivot point...
God Bless,
Doc S
Psalm 23:4 Even though I walk through the valley of the shadow of death, I will fear no evil, for you are with me; your rod and your staff, they comfort me.
PostPosted: Fri Nov 09, 2012 5:20 pm
There is another way to mount the attachment without the use of a drink holder. Most Hobies have twist-n-stow hatches in that position. A flange could be mounted to the lid of the TnS to hold the upright that has the hand levers attached to it.
It would take only a little bit of imagination and creativity to mount something to hold the handle/lever assembly. The overall idea as outlined in the illustration is sound and should work well.
I should add that multiple linkage attachment points could be added to change the amount of mechanical advantage required for operation, additional exercise, etc.
PostPosted: Thu Apr 11, 2013 2:42 pm
To Tom Kirkman's point, here is a photo of a YakAttack MightyMount I attached to my center hatch.
It is a very secure mounting point and YakAttack has all kinds of accessories that may adapt to your need. If not, contact Luther at YakAttack and I am sure he could tool something up for you.
Mike
