It is currently Sat Nov 18, 2017 12:10 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
PostPosted: Tue Apr 09, 2013 12:05 pm
deleted.
PostPosted: Tue Apr 09, 2013 12:34 pm
deleted.
PostPosted: Tue Apr 09, 2013 3:10 pm
dude, that is off the HOOK!...... :o that is a very nice, and clean fab/install job! Pat yourself on the back !!!! The actuator is awesome..
PostPosted: Tue Apr 09, 2013 3:28 pm
Very nice.
Hobie PA14 with a mod or two
PostPosted: Tue Apr 09, 2013 3:34 pm
Very clean!
One question, is there any give to that mount if you should hit an underwater obstruction?
PostPosted: Tue Apr 09, 2013 4:10 pm
fishingfool,
There is no kickback protection in this design. Just don't hit anything!! :D The way I see it, If you're in water shallow enough that you think you might hit something, the motor shouldn't be down in the first place. To answer your question though: If you should hit something, most of the force applied stays contained within the C channel piece and not sent through the plastic. Obviously something would eventually have to give (my first guess would be one of the actuator pins), but considering the relatively low speeds we're talking about, I think you would just simply come to a stop.
PostPosted: Tue Apr 09, 2013 4:35 pm
A very good job, congratulations.
PostPosted: Wed Apr 10, 2013 2:39 pm
Carl, just another AWESOME project, really nice craftsmanship. You ROCK, thanks for sharing your ideas and with all of us.
2012 PA14 Dune
Life, Liberty and the pursuit of fish!
PostPosted: Wed Apr 10, 2013 4:25 pm
That is great. Best install I have seen yet. That is the crate that I am looking for. Where did you get it?
PostPosted: Wed Apr 10, 2013 7:07 pm
Thanks for the comments guys!
RLC,
It's a 2 liter soda bottle crate that folds flat. You can google "folding crate" and find one to fit your needs.
Carl
PostPosted: Thu Apr 11, 2013 5:37 pm
Thanks for the info will check it out.
PostPosted: Thu Apr 11, 2013 8:44 pm
Great job well done.
I'd however suggest to change the actuator arm connection to a "hook setup" so that the motor can kickback should you hit the bottom.
PostPosted: Fri Apr 12, 2013 2:24 am
Very nice!
PostPosted: Fri Apr 12, 2013 6:09 am
Thanks for the comments guys! Gaz, you are correct. This unit does need a kickback function. I mainly fish big lakes with the PA, so I wasn't really considering that as being an issue. Like I said though, this is a prototype and I've already begun to make design improvements. I think I will scrap this one and start over. The new one will have full retraction, kickback, and steering. It will also be easily detachable.
Carl
PostPosted: Fri Apr 12, 2013 8:33 am
Another incredible bit of craftmanship, CK! Very nice.
cron
