It is currently Fri Nov 17, 2017 11:36 am
 Post subject: 2" or 3"???
PostPosted: Tue Apr 30, 2013 4:17 pm
I just replaced my PVC bunks to 3" and wanted to know if you all had a preference? My second try was hugely improved over my first ones, hopefully this time my hardware won't come off... Ill try to post pics later...
 Post subject: Re: 2" or 3"???
PostPosted: Tue Apr 30, 2013 5:30 pm
I used 2 inch on the original design because it fits the hull troughs better. It's also more flexible and conforms to the hull easier, which is what I was after when I came up with the idea.
I'm sure other sizes can be successfully employed.
PostPosted: Tue Apr 30, 2013 6:29 pm
Thanks for the reply Tom. I really appreciate all your videos on YouTube. I will soon be changing my trailer setup to mimic your rig to hold 2 PAs. One more question, how do you rig your bolts? Do you apply loctite? Do you do two nuts?
PostPosted: Tue Apr 30, 2013 6:48 pm
Nylon lock nuts. That allowed us to leave them just slightly loose in order to allow some movement of the parts and pieces due to temperature changes, loaded, unloaded, etc.
