It is currently Mon Nov 20, 2017 11:59 pm
 Post subject: Question about sidekicks
PostPosted: Mon May 06, 2013 10:51 am
Hello All,
I recently added a sail kit and side kicks to my 2010
revolution. I was considering adding a cross bar
to my adventure so I could use the sail on it.
when I was looking at the new accessary catalog
I see right above the cross bar a part called
an adventure adapter plate. I can't seem to find
a picture of this part so I don;t know what it is.
Is this something I need?
Also, do I need to purchase a daggerboard
for running the small sail on a adventure.
Thank you for your help.
PostPosted: Mon May 06, 2013 11:54 am
Hobie Tech / Moderator
The Adventure adapter plate is just something to add a Sidekick onto an Adventure hull using the existing inserts designed for the Island kit rather than drilling holes to attach the hardware like you did on your Revo
You can't use a Dagger board on any other model but the Adventure - it isn't compatible with any other model, but would help nicely on the Adventure you own.
If you want to take your Sidekick and put it on a 2nd hull - you need the center crossbar and hardware so that you can easily transfer the kit between 2 kayaks - it's part # 72062062
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Mon May 06, 2013 11:56 am
I think there are adapters so that you don't have to drill holes in an adventure to mount the sidekick crossbar. It simply uses the existing holes (and perhaps the screws) that are already predrilled where the amas and akas would attach if you converted it to an Adventure Island.
2011 Hobie Mirage Adventure
Caribbean Blue
ST Turbo Fins, Sail Kit (w/home-made furler), Sailing Rudder, SideKick Ama Kit, Daggerboard, iComfort Seat Pad, GoPro Hero3+, RTIC SoftPak 30, Seattle Sports Scupper Swift Cart
PostPosted: Mon May 06, 2013 12:10 pm
jbernier - would it affect the sailing performance in any way to mount the sidekicks in front of the kayaker rather than behind the seat? I thought it might help with stability to mount them forward of the kayaker, closer to the sail, when a gust of wind hits the little sail kit and causes it to heel over. Also, might make it more stable when moving forward on the kayak. Thoughts?
Caribbean Blue
PostPosted: Mon May 06, 2013 1:49 pm
It makes no difference - forward or behind - they still provide the same amount stability - just might get in the way of paddling stroke... so just be aware of that.
Jacques Bernier
PostPosted: Mon May 06, 2013 4:02 pm
Ok. Thanks for the info.
Caribbean Blue
PostPosted: Thu May 09, 2013 8:36 am
Thank you all for the help.
I installed the crossbar and am ready to go.
I still don't know for sure if I need a daggerboard
for the adventure with a small sail.
PostPosted: Thu May 09, 2013 9:15 am
[quote="beardedguy"I still don't know for sure if I need a daggerboard
for the adventure with a small sail.[/quote]
It will help a lot. Maybe borrow one from an AI (from a friend or your dealer) to try.
PostPosted: Thu May 09, 2013 11:27 am
You should (will) find that the daggerboard transforms your boat's upwind sailing performance. I qualify my normal "will" to a "should" because I don't personally use any outriggers, but on my boat (Adventure Island hull only) the difference that the daggerboard makes upwind (and w.r.t downwind stability) is huge.
The boat will point much more into the wind when sailing, which is the perennial issue for every sailing vessel - how do you get the thing to sail upwind?! - and the stability feels better in that it feels less tippy generally with the extra weight of the mast aloft and you probably get a bit more time to react to the threat of a capsize... both useful factors if you sail without outriggers.
PostPosted: Thu May 09, 2013 1:57 pm
Thank you Stobbo,
I've read many of your post and know that you are very knowledgable
on these things. I have one of the best hobie dealers in the world here
with Fastlane sailing center so I'll just head on down there and pick
one up.
Thanks again.
