It is currently Fri Mar 24, 2017 10:12 pm
 Post subject: Bent fin on mirage drive
PostPosted: Sun May 05, 2013 5:49 pm
Pin is sticking out on one of fins my maiden Voyage today and it is bent about an inch up from the bottom of the end of the thin and post that runs the length of the side with the setscrew and pin is sticking out about 1/2 inch how do fix
PostPosted: Mon May 06, 2013 9:24 am
Pull the fin and fix the tear with Marine Goop - wonderful stuff. As for the shaft, it can be straightened in a vise, or take a couple pairs of vise grips between the bend and manually straighten it out. I straightened mine at the launch ramp once simply by placing the shaft on the concrete bend side up and hitting it with a flat rock. Straightened right out...
PostPosted: Mon May 06, 2013 2:30 pm
Shouldn't have just happened! What did you do... did you hit something ?
PostPosted: Mon May 06, 2013 3:06 pm
Flat rock always works :mrgreen:
PostPosted: Tue May 07, 2013 11:02 am
A layer of Gorilla Tape over the damaged area works wonders too.......If you use Marine Goop, I would still cover the "repaired area" with Gorilla Tape.
It's the pits to damage a new fin and bend the mast.
If this is the standard fin, you could consider upgrading to the Turbo fins and save the originals as spares.
The Turbo fin is a super improvement over the standard fins.
Dr.SteelheadCatcher
Hood River, OR
PostPosted: Tue May 07, 2013 1:49 pm
By the way, Marine, Plumbers, Sportsmans, Home, Shoe, etc., GOOP is GOOP. Same product. Only the label on the package is different.
If you like using a smaller nozzle, and one that doesn't plug as easily, try E6000. It's also, GOOP.
PostPosted: Tue May 14, 2013 6:44 am
I have to say that striking the rod with a rock does not sound like such a good idea. There are expensive plastic parts where you are hitting with a rock.
Take the fin off, place the drive on the ground and bend slowly with your hands.The shaft will bend fairly easly and your not striking it with a rock.
LOL
Jim
