It is currently Tue Jun 27, 2017 12:16 am
PostPosted: Sat May 04, 2013 9:43 pm
In between the mounting board and the handle on the PA? I feel this is a good position for rod holders but it seems to be a really tight fit. Another thing is will it be strong enough in this location to support a striper run on a rod as I am trolling? I have seen this approach taken on the outbacks and revos but I want this on my PA. To be honest, I have already installed them but just don't feel comfortable about their strength. I will take some pics in the morning as I do have a GTG planned on Ray Hubbard in about 7hrs... Please share any feedback and tell me I am crazy if this fails... Thanks, Adrian
PostPosted: Sun May 05, 2013 5:52 am
If you used the matching YakAttack FullBack backing plates, it should be more than enough.
PostPosted: Mon May 06, 2013 7:08 am
Here are pics of the install. It seems fine for now and if feels so natural. No need to lean forward out of the seat to get the rod. I did some trolling yesterday and caught a half dozen fish on the right side holder without issue but then again these were just sand bass
PostPosted: Mon May 06, 2013 7:15 am
Don't know what all that stuff is. I have a mount for the Bass Pro rod holders at that spot. Four #14 stainless sheet metal type screws. Holds fine with spanish mackeral runs. Should be no problem for a striper. You can see the holder here aft of the Humminbird Fish Finder
Hobie PA14 with a mod or two
PostPosted: Mon May 06, 2013 4:05 pm
Thanks AEPA. I have heard the gear trac from yak attack carries 60 lbs per screw so i should be good for 240 lbs per side. I could only hope to ever max that out ;-)
PostPosted: Mon May 06, 2013 6:57 pm
How are they attached - must be thru-bolts? How do you reach the underside to thread the nuts?
Larry
PostPosted: Wed May 08, 2013 5:13 pm
If you are mounting it on the port side for a rod holder, it will come unthreaded if it takes a hard strike from a big bass....I use aluminum ram tubes and put a regular ram ball on the mounting board because of this, since I troll from the port side. Just something to think about.
-Matty
PostPosted: Wed May 08, 2013 8:19 pm
Larry
This is exactly what I was thinking. How on earth do you get to that to thread a bolt with a nut on the bottom side? I think that would be a great place for a track, but I'd be very worried about using it without threading a nut on the bottom side. You never know what kind of monster is going to hit your rig... especially if you go in saltwater or BTB.
Maybe someone else has threaded a nut there and can tell us how.
PostPosted: Fri May 10, 2013 4:19 am
jesmo5 wrote:
Larry
If you take the route LT mentioned using the YakAttack GearTrac 175 series, check first to see if you have the necessary width for the Full Back Mounting Plate. If you have the necessary width, then the Full Back actually has integrated S/S nylon locking nuts already. All you need to do is get the threads started on two of the bolts securing the GT175 on top and the rest will seat perfectly. I used this approach on my son's old Tarpon 100 in an area that was tight fit, and that mount is so strong now, you could lift and tote the kayak from that mounting point alone.
If the GT175 is too wide, you can opt for the GT90 series which is the narrower version. The smallest one offered is the one with the 3 mounting holes. There is also a backing plate for this trac as well but it is a standard backing plate where you would need to use a nut driver or a ratchet with an extension and socket to thread a locking nut on the bolt most likely due to the tight fit and the hull design.
Be mindful of any cable routing or other items like FF or electrical power wiring you migth have in the same area on your respective PAs.
2017 Hobie Revolution 13 & 2015 Outback
Froggin' For Bass and Other Kayak Adventures
PowerTeam Lures - deadly on bass!!! use promo code "HANOVER" at checkout for a 15% discount
PostPosted: Sat May 11, 2013 7:45 pm
Actually, I'm just referring to how you get the nut threaded since the placement on a PA 14 would be really hard to reach (if it is even possible), because of the small space, and its awkward position.
PostPosted: Sat May 11, 2013 11:17 pm
This video should answer your question (actually two videos). A backing plate with integral nuts is used so you don't have to worry about holding a nut to thread and a tool called a "rigging bullet" is used to position the backing plate into positions in the hull far away from hatch access. Luther Ciphers explains and demos this installation process well in these videos. It's a very slick solution. Enjoy.
Introduction: http://www.youtube.com/watch?v=vzuXaMw7c5k
Demonstration: http://www.youtube.com/watch?v=mKrh7ASC4Hw
_____
_<>-+ copterchief
PostPosted: Sun May 12, 2013 2:34 pm
That is very helpful! Thanks!
PostPosted: Sun May 19, 2013 12:01 pm
My trax are screwed directly into the mounting board with a drop of Lock-Tight. No backing plate. They aren't going anywhere. Oh yeah, and I screwed every screw in there. I probably could gotten away with only 4. Also, I have a 4" trax on the stern deck with a backing plate.
I talked to a couple guys at the Hobie shop about the flex I'm getting up front, but they assure me, if may flex but it won't give way.
Sandy
Panama City Kayak Fishing Assn
