It is currently Tue Jan 16, 2018 3:54 pm
 Post subject: Contact cement
PostPosted: Thu Apr 25, 2013 6:01 am
I need to repair a neoprene foot rail and the original Stabond contact cement is past it's expiration date on the can by several years. I can't find Stabond locally but the DAP/weld wood type is available. Will it work as well as Stabond?
Mark
2007 Hobie Tiger
 Post subject: Re: Contact cement
PostPosted: Thu Apr 25, 2013 7:45 am
I would open that can of stabond up, see if you can stir it up good, get that top hardened layer off out of the way, then test glue something with it if you still can.
I've had (although a different compound) West System epoxy that was good even after 20 years of original purchase, that worked great right up to the day I finished it off.
I'm not sure about that dap/weld wood type, but I do know that 3m makes some good contact cement/glue You can buy it in can/brush form (probably better way to go) or spray can form (get heavy industrial) Most likely found at Auto parts stores that also sell auto body supplies, some hardwares, maybe homedepot or lowes etc. I've used 3m products on my side rails of my tramp, to install carpet, works good for me.
79 H16 #46803
PostPosted: Thu Apr 25, 2013 12:10 pm
Weldwood in the Red Can will work just fine.
PostPosted: Wed May 22, 2013 5:17 pm
Mark
Weldwood is brand Hobie now sells in the catalogue.
PostPosted: Fri May 24, 2013 12:00 pm
Any solvent base contact cement will work the same.
