It is currently Sun Jun 25, 2017 5:47 pm
PostPosted: Thu Jun 06, 2013 7:20 pm
Hello, I'm new here. I took delivery of a shiny new 2013 PA 14 last weekend. I bought it at Quest Watersports in Ottawa, IL, where they took excellent care of me.
I've only had the boat out twice so far, and I'm absolutely delighted with it. I even caught a 14" smallmouth from it, which was a real treat - catching a strong fish is a very different experience when it can swim under you!
I have about zero experience with kayaks, or boats in general for that matter. That said, I've found one thing about it that I consider rather odd, and that's the placement of the paddle clip.
With the paddle clipped in there (and possibly even without it), the clip will be in the way of the molded-in rod holder. This isn't a big deal, as I don't expect to get much use out of those rod holders, but it seems like a weird place to put it when everything else on the boat has clearly had a lot of thought put into good design.
Anyhow, hello!
PostPosted: Fri Jun 07, 2013 8:31 am
Hobie Tech / Moderator
That looks like the paddle holder has been installed in the wrong position from the factory - we made some assembly errors early on when we switched over to this new paddle clip design. It should be in the forward position (where your shock cord now dead ends) - easy solution, just swap the clip and pad eye and you're all set. I'll take a new photo for you and post in shortly.
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Fri Jun 07, 2013 9:00 am
here is the paddle clip in the wrong location
Here is the correct location
Here is a photo showing with paddle and rod
Jacques Bernier
PostPosted: Fri Jun 07, 2013 9:10 am
Ah, I see. Excellent, thank you. Now I know what I'm doing after work tonight. :)
That is, assuming I don't take 'er out fishing instead!
2013 Pro Angler 14 || 2012 Outback (wife's) || 2006 Suzuki Burgman 650 scooter
PostPosted: Fri Jun 07, 2013 6:04 pm
Does that paddle clip come with all new PA's? Or is this an accessorie?
PostPosted: Fri Jun 07, 2013 7:34 pm
That is not the paddle clip my 2013 PA 14 came with. This actually seems more functional. Mine came with a taco clip mounted to the paddle (Literally screwed into the paddle) :evil: , and I hate it! It clips to the rail, and is constantly in the way, and/or getting knocked off. I've just ordered the quickfist rubber clamp to mount my paddle on the boat more securely, but now I'm not sure I want to do that either.
Anyone have suggestions?
PostPosted: Fri Jun 07, 2013 8:48 pm
It came with mine.
Swapping its location with the pad eye was simple - they just unscrew. I feel like a dork. I was envisioning a difficult bit of contortion inside the hull.
PostPosted: Fri Jun 07, 2013 9:22 pm
Hmmm...I'll have to look into this. My taco clip that came on my PA sucks. I have to bungee it on so it won't fall off. The Velcro ain't worth a (censored).
PostPosted: Sun Jun 16, 2013 4:35 pm
I have the taco clip also. I'm guessing we all have first run 2013's. The paddle holder shown in this thread looks like one of the new Summer 2013 accessories I had my eye on but didn't pull the trigger because I would have installed it just like the thread starter did and giving up a rod holder was not an option for me.
I was going to attempt to unscrew it off the paddle and drill it into the side of the hull like how you hold a paddle on the Revolution but changed my mind.
JB, is there a exchange program for the taco clip owners?
PostPosted: Mon Jun 17, 2013 10:39 am
Hey JB.....Perfect!!! THANKS!!!
Just shared that with our staff and especially the Techies......great solution!!
JohnYaksJax @ BCO
PostPosted: Tue Jun 18, 2013 8:49 pm
I placed an order for the new paddle clip today; $8.99+tax.
PostPosted: Wed Jun 19, 2013 4:07 am
I got my paddle clips yesterday and installed them. I said them I have a PA 12, I put 1 on each side. If you have a 14 you can put the other half in the front hatch. Works great.
PostPosted: Wed Jun 19, 2013 10:09 am
Where did you get your paddle clip?
PostPosted: Wed Jun 19, 2013 5:59 pm
Kayaks by Bo in Titusville, you can get them from your local dealer.
PostPosted: Fri Jun 28, 2013 5:11 am
I hate the "taco" clip as well. I don't use my paddle very often, but it was poorly thought out and limits how I use my paddle. I most keep the paddle broken down on board and only break it out if I am too shallow to peddle.
