It is currently Mon Nov 20, 2017 11:41 pm
 Post subject: Kayak cleaning
PostPosted: Fri Jun 21, 2013 5:12 am
I would be interested to know what you guys use to wash your yacks ? In the past ive used 303 UV protectent. I just pulled my PA out of storage "covered" since 2011. Its perfect but a bit dirty and would like to wash it before applying the 303. Dish soap ? Auto soap ?
 Post subject: Re: Kayak cleaning
PostPosted: Fri Jun 21, 2013 6:13 am
Nothing but Kayak soap :!: Think elbow grease is more important than what type of soap :roll:
PostPosted: Fri Jun 21, 2013 7:11 am
I was actually curious to see what people would say they use too. I spray my mirage drive with WD-40 after every other trip or so when it's dry, but recently I've notice some black greasy stuff getting on the plastic surrounding the drive locks and well. I tried bio dish soap, but it didn't really clean it. What should I use on the plastic? Also, does the mirage drive need to be degreased once in a while?
2011 Hobie Mirage Adventure
Caribbean Blue
ST Turbo Fins, Sail Kit (w/home-made furler), Sailing Rudder, SideKick Ama Kit, Daggerboard, iComfort Seat Pad, GoPro Hero3+, RTIC SoftPak 30, Seattle Sports Scupper Swift Cart
PostPosted: Fri Jun 21, 2013 8:04 am
Yup the same here. The black greasy stuff is on the out side as well. I just dont want to use a degreaser or soap it if can hurt the plastic.
PostPosted: Fri Jun 21, 2013 8:28 am
"Krud Kutter". "409" is almost as good. 8)
PostPosted: Fri Jun 21, 2013 10:39 am
Diver_fcd......I believe the heavy black grease you are seeing is the waterproof marine grease that was used to lube the drive shaft axle......the WD40 has softened up the grease and caused it to "weep/seep" out.......a good de-greaser should cut through the grease around the drive well locks.......then/apply 303 to the area cleaned with the de-greaser.
My suggestion is to be careful where WD40 is applied so the grease remains where it was installed at the factory.....at some point, you need to disassemble the mirage drive moving pieces, clean up and re-grease the shaft.
The FAQ's have some good info on maintenance.......viewtopic.php?f=60&t=12577
Dr.SteelheadCatcher
Hood River, OR
PostPosted: Fri Jun 21, 2013 11:08 am
Thanks for the info, Dr.Steel....
Caribbean Blue
PostPosted: Sat Jun 22, 2013 2:32 am
i've always found dawn dishwashing detergent to be really good for things like this ... definitely won't hurt the boat plastic(s) and has a really nice grease cutting ability.
just don't go overboard and squeeze it directly on the offending spots ... mix a small amount (say a teaspoon) in 8oz of water and work it with a sponge, soft brush, rag or sturdy paper towel.
make sure to rinse it off with water afterward.
PostPosted: Mon Jun 24, 2013 3:40 pm
Simplegreen!!
PostPosted: Mon Jun 24, 2013 4:02 pm
Tide (powder) has been used for power boat cleaning for years :!:
PostPosted: Tue Jun 25, 2013 9:54 am
303 is not a cleaner, it's a protectant , apply it just to the top deck areas that get all the sunlight after you clean and dry the yak.
Krud Kutter as someone said above is a great cleaner and is free of solvents.
PostPosted: Tue Jun 25, 2013 9:57 am
Another vote for Simple Green. Anywhere from a teaspoon in a gallon to full strength (depending on the job) works great. Smells good, too!
Pro Angler-14 owner
PostPosted: Thu Jul 04, 2013 4:07 pm
beardedguy wrote:
Simplegreen!!
Is Simple green too harsh for a i14t Inflatable provided it is fully rinsed and allowed to dry before bagging?
