It is currently Mon Jun 26, 2017 10:37 pm
 Post subject: From j-22 to a wave
PostPosted: Mon Jul 08, 2013 1:12 pm
First off wanted to say hello as this is my first post. I recently took a sailing class and learned on a j-22. Other than the 4 days of sailing in he class that has been all my sailing experience. Last week I moved to Florida and joined a sailing club. They have an assortment of boats that can be used and today I took out a hobie wave.
Everything thing pretty much went well. I had a good time sailing and managed to sail solo and make it back to the dock. I'd call that a success for my first solo sail! I had a few questions.
I don't know if this is specific to Cats or was I just out of practice. Today as I was jibing and tacking I found myself having to turn much further away from the wind to gain momentum. I think I'm trying to say I had difficulty sailing upwind? I think that's what I mean. On the J-22s I never had any issue keeping momentum or sailing on a close reach after a tack. Is there a different way to do this on a cat?
And beyond that question what adjustments should I make when transitioning from what I learned on a j-22 to a cat or specifically the wave.
My goal is to eventually buy my own boat and go on long overnight trips. But for now I'm just having fun learning and playing on cats.
Dom
 Post subject: Re: From j-22 to a wave
PostPosted: Mon Jul 08, 2013 4:22 pm
Tacking on cats can be challenging. The boat is light (little momentum) and you have to push two hulls through the water sideways to turn (lots of drag) so the boat will slow quickly as you initiate a tack, especially if you try to tack short (by really pushing hard on the tiller). Once the boat is stopped/significantly slowed, and the battens pop to the new tack you may find it helpful to drive the boat slightly off the close haul course as you sheet in to accelerate. Then as the boat reaches speed, ease it back to a close hauled course as you continue to sheet in. Don't be afraid to sheet in hard. The boat only has a three to one sheet and a long sail leech (back edge) that will try to twist off with wind pressure. Also of help in tacking, sheet in hard as you push the tiller over to initiate the tack. This will help to accelerate the boat and weathervane the boat too. Then, once the sail starts to luff/backwind, you need to sheet out to keep the sail from acting as a weathervane stopping your turn, now away from the wind. While all this is going on, you need to keep the tiller turned as you crawl across the trampoline to the new windward side. One more note, keeping your weight on the windward back corner as you start the turn and as the sail starts to backwind will aid in keeping the bow up (less boat in the water, less drag) and once the sail is past head to wind will help the wind on the now windward bow pushing the boat around. But don't sit there too long, or the boat will capsize towards you (another reason to sheet out once head to wind).
Jibing is easier, as the boat never stops. As you start to turn away from the wind, crawl to the middle of the trampoline, keep the tiller turned, grab the three to one bunch of line in the middle, then when the boat is dead down wind, pull the mainsheet bundle across to the new jibe set. The reason you pull the sail across is 1) it makes the sail swing when there is the least pressure on the line 2) You will never be surprised by an accidental jib (if it happens before you throw the line, you will feel it) 3) it eliminates the need to sheet in and unsheet as you jibe (also helps to eliminate round up/capsize potential).
PostPosted: Mon Jul 08, 2013 4:58 pm
Wow lots of info here. I'll have to read it a few times to take it all in.
