It is currently Fri Jan 19, 2018 3:28 am
 Post subject: Righting systems
PostPosted: Mon Jul 29, 2013 8:37 am
Has anyone used or seen the righting systems that use a long pole for additional leverage that attaches to the crossbar under the mast? This would be an alternative to the righting bag shown in the accessory catalog. It looks as if this system stays tucked up under the tramp and quickly unfolds if the boat is capsized.
 Post subject: Re: Righting systems
PostPosted: Mon Jul 29, 2013 9:34 am
See this post for a home made version. It's not specific to the Getaway but I'm sure you could adapt it to your needs.
http://www.hobiecat.com/forums/viewtopic.php?f=13&t=44504&p=216094&hilit=righting+pole#p216094
PostPosted: Sat Aug 03, 2013 3:13 pm
I tried to design one, but I had a terrible time trying to attach it under the mast. From what I can see, most of these systems make use of a dolphin striker protruding out below the mast - which don't think the Getaway has. In fact, even the nut under the mast is covered by the trampoline. In the end, I did connect a pole way by running a line between the two bungee rings - and found myself dangling from the pole at full extension, to no avail.
I have only had success righting the Getaway solo with a righting bag. It takes some getting used to, but it works.
PostPosted: Tue Aug 06, 2013 6:36 pm
Thanks for the input
The next time I take her out were going to practice righting the boat and I want to try it solo with the sails rigged
PostPosted: Fri Aug 23, 2013 6:46 pm
We had our first Getaway capsize (and my wife's first capsize) last week. I was pleased with how easy it was to right, I think it's much easier than the H-17 I previously owned.
After we hit the water, I helped my wife onto the hull. I uncleated the sheets, and we stood on the bow. It took a while, but the boat turned most of the way into the wind. I swam the bow around so the wind was coming from between the mast and the bow. It was much easier to swim the bow than the mast tip, for some reason.
My wife and I grabbed the righting line and over she came! My wife was hesitant to lean back much, so I pretty much righted it solo. I do need to figure out a more graceful way to settle it in-it pretty much slammed down and dunked me again.
A bit of a scramble to get aboard, but not to bad. I do have to figure out a way to help my wife aboard more easily.
Side note-we have the Onyx auto inflate vests. Holy cow, they go off like an air bag. If you use these, rip the velcro loose on both sides and refasten a little off center so they open more easily. We both had one side velcro fail to open, so the inflated side was giant and choked us.
Yet another Bob!
PostPosted: Tue Aug 27, 2013 1:07 pm
hobie1canobe - how long was the pole you used?
Dave
PostPosted: Sat Sep 21, 2013 9:20 am
While connected under the mast during travel it reached the rear crossbeam and was secured under the boat there. It was not an ideal system. I am sure someone could get one to work, but I'm most comfortable with the righting bag.
PostPosted: Mon Sep 23, 2013 11:18 am
hobie1canobe:
I would really like to talk to you to get some more information. Please e-mail me at wxup@yahoo.com.
Dave
PostPosted: Fri Oct 25, 2013 5:39 pm
I have just mounted the one from Murray. the main part is a universal ujoint the like was used in the first windsurfs as a mast foot. in fact a part of windsurf mast makes the pole that wil be inserted into the ujoint.
this is secured to the center of the main cross beam by 2 rivets into a stainless steel bar that supports the ujoint. there are different setup possible so I will let you know when i have fully tested it. My idea is to right it solo. But I guess that I am dreaming on.
The Black Pearl
Sailing a black getaway with black sails in the indian ocean.
PostPosted: Mon Apr 07, 2014 8:29 am
dorienc,
We had the same problem with climbing back on after taking a "swim". We now rig a "slip step" on the crossbar so we have a step to use to climb back onboard. It's available from cobrasailing.com and lays onboard until you need it. Makes life much easier......
Tim and Brentz
PostPosted: Tue Apr 08, 2014 7:40 pm
Ah, thanks, Tim and Brentz. Actually, I've got a daisy chain for aid climbing that I can use, I just hadn't thought of it! Same idea.
Bob and Dorien
Yet another Bob!
