It is currently Fri Apr 19, 2024 9:44 am
PostPosted: Mon Aug 05, 2013 1:38 pm
We purchased a Hobie Kayak with Mirage drive. We purchased a 2nd last month. The Mirage drive that came with our 1st purchase works fine. But the second Mirage drive does not easily lock in place. I measured the two metal shaft dimensions.
For the unit that inserts easily, I measured 16.8mm beyond the plastic on both sides
On the troublesome unit, I measured 16.8mm on one side & 17.8mm on the other.
I wouldn’t think that 1mm would be enough, but it appears to be. Suggestions?
Thank you,
-Robert
PostPosted: Mon Aug 05, 2013 3:20 pm
Try tapping the longer end of the shaft with a hammer to even them out, see if that helps.
PostPosted: Mon Aug 05, 2013 3:54 pm
Thanks, I wondered if that was OK.
-Robert
