It is currently Mon Jan 22, 2018 7:22 pm
PostPosted: Thu Aug 15, 2013 9:04 am
First of all, I'd like to apologize for the mistakes I'll make in English : I'm writing from France, English is not my native language.
I bought this summer a 1999 Hobie Tiger. On the 1999 version the trampoline selvedge (not sure this is the right word?) went into the the beams, of course, but also on its sides into the hulls. Here is my problem : the hulls have a crack at the junction with the trampoline so they are not anymore stiff enough to hold it in place. Please have a look at the following pictures wich are easier to understand than my poor technical english :
The pictures inside the hull are taken from the front hatchway using a camera on a pole. As you can see the crack goes from in front of the frame 3 to the frame 4. The frame 3 is unglued from the hull and the glass fabric reinforcement on its rear is unglued too.
What should I do to fix it?
I guess it would be easier to operate if the middle pannel of the hull (ref 18090075) was removed; is there a way to remove it without breaking it? how is it glued? (resin + glass beads?)
Thanks per advance for your answers ;)
PostPosted: Thu Aug 15, 2013 10:07 am
Hobie Tech / Moderator
I sent you some PDF instructions showing repair methods for old Tiger tramp track issues check your inbox.
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Thu Aug 15, 2013 11:05 am
Wow, what a fast answer :) Thank you for the PDF instructions. I know have a better idea on how to proceed.
Could you tell me more about the putty used to glue the deck cap? it looks like resin mixed with something, is it glass beads? silica?
PostPosted: Thu Aug 15, 2013 11:06 am
That's called 1 pound putty - it's polyester based - the instructions should be really clear about the process - best of luck.
Jacques Bernier
PostPosted: Sun Dec 29, 2013 2:51 pm
Dear Friends could you please forward those PDF to me as well ??
many thanks
Fabio
