It is currently Mon Jun 26, 2017 9:31 pm
PostPosted: Thu Aug 15, 2013 8:16 pm
Hobie Team Member
ImageLoadedImageImageImage up PA14 (LOWER) & PA12 (upper)[img]http://img.tapatalk.com/d/13/08/16/jy9y2uze.jpg[/IMG[IMG]http://img.tapatalk.com/d/13/08/16/u2yge2a5.jpg[/img]ImageImage]
Sent from my SCH-I545 using Tapatalk 2
Fishing is not a matter of life or death... It's much more important than that!
PostPosted: Fri Aug 16, 2013 4:08 am
You have just completely regained my confidence in being able to move these two bad boy 14's out to the water! Thank you!
PostPosted: Sat Aug 17, 2013 4:49 am
It looks like 1 is a 14 and other a 12? Do you think there would need to be support towards the back on an upper deck 14? I have a topper and would like to get both inside. It looks like it wouldn't work if there is anything attached that rides up very high on the upper one?
PostPosted: Sat Aug 17, 2013 7:30 am
Tim,
like the use of the plasitc conduit - what size is it?
Thanks for photos
Alan
2012 PA14 Papaya
2014 PA14 Dune
"If you must choose between two evils, pick the one you've never tried before!"
PostPosted: Sat Aug 17, 2013 9:15 pm
Simple and effective. Good setup.
Hobie Pro Angler
PostPosted: Sun Aug 18, 2013 6:40 am
What will keep the top yak from coming through the window if you hit you breaks? Just wondering if you tie down other area not shown in the pictures... Good Luck
PostPosted: Sun Aug 18, 2013 3:37 pm
I would expect a piece of plywood may work between the PA and window to keep it from coming crashing through.
