It is currently Thu Jun 29, 2017 2:21 am
 Post subject: AI Aka weight capacity
PostPosted: Thu Aug 22, 2013 4:01 pm
I saw a post where an AI or TI owner used their Island as an outrigger boat and installed a standing/casting platform on the Akas and this looked like a great way to fish the flats.
Does anyone know the weight capacity of the Akas or can anyone speak to how much weight they have put on them?
Sent from my iPhone using Tapatalk 2
Mike
PostPosted: Thu Aug 22, 2013 5:48 pm
Unless you're extremely obese (not saying you are) you can stand on one side of the AI on the tramp or a haka and you won't submerge the ama on that side.
PostPosted: Thu Aug 22, 2013 5:54 pm
Good question. I know I can easily stand on a TI ama without sinking it, but not on an AI.
My best guess in salt water is 125 pounds (AI) and well over 200 pounds (TI) flotation.
PostPosted: Thu Aug 22, 2013 6:49 pm
I'm 230lbs. Is that more than they can handle?
Mike
PostPosted: Thu Aug 22, 2013 6:50 pm
Does anyone know the capacity?
Mike
PostPosted: Thu Aug 22, 2013 7:57 pm
Basically what kayaking bob said. At 230lb on the AI Ama, your too heavy, would submerge it, with all your weight on that one Ama. Your even pushing it on the TI single Ama. But if you were putting some of the weight on the main hull along with say a haka over the akas (straddle). You would be fine with the AI. See specs on weight for AI and TI. 350lbs, 600lbs respectively.
You could even add a Haka over the two Hakas perpendicular for a smooth walking area? (never seen it done, but why not if standing and casting is a priority)
Mark
Costa Rica Kayak Guide
http://www.cryaker.com
Tandem Island- 2013
Sport - 2014
Revolution 11-2015
PostPosted: Thu Aug 22, 2013 10:22 pm
Funnily enough, I HAVE tested this! It takes 100kg (220 pounds) to put an AI ama underwsater (just) and 150kg (330 pounds) to do the same to a TI ama.
BUT this is with the weight directly above the ama, but if you put a haka halfway between hull and ama, you could double these numbers (of course you wsouldn't though)
PostPosted: Thu Aug 22, 2013 10:37 pm
Tony, I'm very surprised how high of a measurement you got for the AI. The one time I flipped an AI over, I stepped on one ama and was able to sink it to roll the boat back over without folding in the ama. (I rolled the boat in 5 foot waves with many more on their way and adrenalin took over!).
I weigh maybe 170-190 with gear. I don't doubt your expertise and accuracy. It's just funny that I was able to flip it so easily, mostly using my weight...
PostPosted: Fri Aug 23, 2013 4:39 am
Kayakingbob:
It's sometimes amazing what people can do when their adrenalin is pumped up. We have all heard of people lifting cars off of other people in similar situations, whether this is true or not, I would have to think that because of your experience you instinctively knew what to do to get out of what sounds like a very bad spot.
I guess the point I'm trying to make is even though the AI/TI won't flip in 99 percent of the conditions, it's that 1 percent that will get us, unless we practice and instinctively know what to do in the off chance something like this does happen.
I'm guilty of never actually never practicing the published righting procedure on my TI. Though I have dumped plenty of sunfish and sailing kayaks I suspect either the AI or TI is a little more difficult to right, probably would not be a bad idea for all of us to do it on purpose at least once.
PostPosted: Fri Aug 23, 2013 5:19 am
I finally found the post I was referring to: https://www.hobiecat.com/forums/viewtopic.php?f=69&t=47693&p=210641&hilit=casting+platform#p210641. It was by PutAwayWet.
It appears the weight distribution would be similar to that of a Haka or tramp so I would imagine I would be ok as long as I don't venture too close to the Ama side.
I think this could, potentially, be a superior way to sight fish as your vantage point would be even higher than from the PA (not counting those who stand on their coolers).
Mike
PostPosted: Fri Aug 23, 2013 6:20 am
Bob, I was told by the person who sat on the AI ama that he weighed 100kg. I weighed a bit under 150 when I tried to sink the ama on my TI, and we reckoned another 10kg would do it.
PostPosted: Sat Aug 24, 2013 5:55 pm
Here is PutAwayWet's casting platform.
But, I like CR Yaker's suggestion of using a simple haka as a platform. CR actually suggested using 3 haka's--2 hakas deployed as usual (1 on each side of the hull, close to the hull) and the 3rd spanning them. This would allow casting from either side of the hull, and, since you are not standing near the ama, submerging the ama should not be a problem. Now, my camping mentality prefers using only 2 hakas. You could put the 2 hakas side-by-side to give a larger platform (and maybe sinking an AI ama), or you could deploy one close to the hull and the 2nd perpendicular and spanning the hull--this 2nd one would allow some access to the opposite side if the fish you are targeting moved.
In any case, I like the idea of using the hakas as a casting platform--even when out camping, but on your day off from traveling. Once again, we are looking at the great versatility of hakas!
PostPosted: Sun Aug 25, 2013 1:16 am
I believe Roadrunner once stated the buoyancy of an AI ama was 220# and he's usually right about these things in my experience.
PostPosted: Mon Sep 16, 2013 1:07 am
On a closely related issue, if you take a passenger on a tramp, how much clearance do they have above the water? Assume flat, fresh water, 90kg (200lb) captain, 60kg (130lb) passenger. I'm interested in taking my wife out on a kayak plus single ama setup.
Any ideas?
Thanks.
PostPosted: Tue Sep 17, 2013 6:58 am
flat water, tight tramps, and 130lb not moving around may stay dry .. add any wave, movement, or a good meal and "WetTush" may become their nom de plume
Alan W.
.. and a Hobie Outback SUV
