It is currently Fri Apr 19, 2024 4:46 pm
 Post subject: Mast base upgrade?
PostPosted: Fri Sep 13, 2013 12:48 pm
I picked up a 1996 Wave. It has the older mast base (Hobie 14 style). The hole where the pin goes when you step the mast has broken, so it can't hold the pin anymore. Should I just replace the mast base, or should I replace the cup as well? Is there any advantage to upgrading to the newer style mast base and cup? Is it a direct replacement? Thanks in advance.
 Post subject: Re: Mast base upgrade?
PostPosted: Fri Sep 13, 2013 2:06 pm
I would just replace the mast base. Less expensive than replacing with the newer version parts.
PostPosted: Sat Sep 14, 2013 2:07 am
Thanks.. Do I need to use the mast step link kit? I'm a newbie to Hobies. Can't find rigging instructions for the older Waves and see two different stepping instructions for H14 stepping.
PostPosted: Sat Sep 14, 2013 9:13 am
Yes, you need the link. Same is used for Hobie 14/16. There may be two step ideas for H14 and Wave would be similar. One uses the link which is safer.
