It is currently Wed Apr 24, 2024 12:28 pm
PostPosted: Sat Sep 21, 2013 8:33 am
I have a 2014 pa 14 I came with two round foam peices that came with it .When I got it they were just floating arounf in the haul of the boat . Dose any one know were they go?
PostPosted: Sun Sep 22, 2013 4:28 pm
Post a picture. I have a 2014 PA14 and mine did not have them that I know off
badbill
2014 Hobie Pro Angler 14
PostPosted: Mon Sep 23, 2013 8:55 am
Short ones are typically floor support.
PostPosted: Mon Sep 23, 2013 11:27 am
On my P/A the two round foam pieces are floor supports that fit directly under the Vantage Seat, supporting the front legs. There is actually a groove in the top of the foam support that coinsides with a ridge on the underside of the floor.
Jeff
Jeff N.
Pro Angler 14 in Dune
Jackson 'Cuda 12 in Earth
"There is certainly something in angling that tends to bring serenity to the mind"
Washington Irving
PostPosted: Mon Sep 23, 2013 7:58 pm
Likely flotation and typically zip tied to scupper pipes. Don't think foam makes for good structural supports.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
Alan
2012 PA14 Papaya
2014 PA14 Dune
"If you must choose between two evils, pick the one you've never tried before!"
PostPosted: Tue Sep 24, 2013 7:12 am
Jeff
You are correct :!:
PostPosted: Tue Sep 24, 2013 3:00 pm
thanks I will check it out shoot out a picture. It would be helpful .
PostPosted: Tue Oct 01, 2013 10:16 pm
Wedge them in the hull under the seat area. You'll be good.
