It is currently Thu Apr 27, 2017 2:10 pm
PostPosted: Fri Oct 11, 2013 9:28 am
I am replacing a 2010 PA with a 2013 model. Will the accessory boards from the 2010 fit the 2013? I have Yak Attack tracks already attached and wonder if I can simply move them to the new hull.
Alan
2012 PA14 Papaya
2014 PA14 Dune
"If you must choose between two evils, pick the one you've never tried before!"
PostPosted: Fri Oct 11, 2013 10:11 am
I'm guessing they are the same size. No reason to believe they would be any different. The models prior to 2013 had the front screws held in by nuts on the back side. So you will need to be handy with a wrench and have some dexterity to remove the screws. The 2013 and up have all the screws mounted into recessed threads.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
2012 Pro Angler 14 (owned now by a good friend)
2013 Pro Angler 14 - Dune
2015 Pro Angler 14 - Papaya
PostPosted: Fri Oct 11, 2013 11:06 am
There has been no change in the mounting boards.
We also show that both the PA12 and 14 use the same boards.
PostPosted: Fri Oct 11, 2013 11:23 am
Thanks Matt, good to know.
Alan
2012 PA14 Papaya
2014 PA14 Dune
Users browsing this forum: Bing [Bot] and 4 guests
