It is currently Mon Apr 15, 2024 9:42 pm
PostPosted: Sat Oct 26, 2013 6:05 am
Wanting to put rectangular scotty flush mounts up front of the mesh holders for rod holders. Have read some post that the location of these mounts can be restrictive when pedaling. Anyone have experience using the scotty flush mounts?
Open for suggestions.
PostPosted: Sat Oct 26, 2013 6:36 am
Scotty makes some nice rod holder extenders that will elevate your rod to prevent any peddling clearance issues....check out this link http://scotty.com/fishing-gear-equipmen ... enders.htm
This photo shows what I did on my 2010 Outback to provide clearance.....Image
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sat Oct 26, 2013 7:23 am
Here you go - I've fitted the #244 flush-mounts to three Revos, a Sport and now, an A.I.
It can be a bit fiddly to get some of the nuts on, but it's not too tricky.
This is how I did it:
http://www.akff.net/forum/viewtopic.php?f=95&t=36465
I use the Scotty 429 Gear Head Mount Extenders, along with the Powerloc rod-holders.
Here they are installed on my ex-Revo:
Cheers,
Mike.
PostPosted: Sat Oct 26, 2013 5:52 pm
Thinking not installing rod holders on front of Revo, have rear rod holders and rod holders on crate. Just lay rod horizontal when pedaling.
Anyone not install rod holders on front of their yak?
PostPosted: Sat Oct 26, 2013 6:12 pm
That's what I would do. Have done both. Prefer in back for trolling. Keep the area clean in front of you for landing fish, at least one side.
Mark
Tandem Island- 2013
2 - Sports - 2014
PostPosted: Sun Oct 27, 2013 6:39 pm
Mingle,
I like your handles. I have short arms and was wondering how you were able to bolt down the handle behind your seat. I can't reach this section regardless if I go through the center or stern hatches. Thanks!
PostPosted: Mon Oct 28, 2013 11:55 am
Cheers,
Mike.
I use that exact same setup on my Outback but I also have the slip disks between each set of geared teeth to make it easy to fine tune and adjust.
PostPosted: Mon Oct 28, 2013 4:01 pm
My arms must be slightly longer than yours! I managed to reach in through the centre hatch (at the extreme extent of my arms!) to attach the nyloc nuts to the screws.
You might be able to do it if you use a socket and ratchet to hold the nut, which someone else screws it in from above. The extra handles made thing much easier to move the Revo around.
I'm curious - where did you get the 'slip-disks' for the Scottys?
Cheers,
Mike.
PostPosted: Wed Oct 30, 2013 8:14 pm
Thanks Mike. I'll reach in with a socket and see if I am hitting that zone before drilling.
As far as the slip disks, try Hook1 or Austin Canoe & Kayak websites.
