It is currently Mon Mar 27, 2017 10:15 pm
 Post subject: Painting a pro angler
PostPosted: Fri Nov 15, 2013 7:54 am
Hello,
I am looking to buy a pro angler was found a good deal on a PA 12. However, it is yellow. Is there anyway to paint these things in a reasonable fashion?
Thank you in advance.
PostPosted: Fri Nov 15, 2013 10:22 am
23mako wrote:
Hello,
Unless you're using it to hunt with, I cannot understand why you would not like the Papaya Yellow color. It probably provides the best color from a safety standpoint to be seen on the water by other boaters. Can it be painted? I would suppose so if you used a paint designed for application on a plastic surface. You would have to sand and prep it to paint it. And once the paint started to age or start flaking off or get scratched off, the PA would start to look bad.
I wouldn't even consider painting a PA if I didn't like the color. I would find one in a color I liked versus going the route you are suggesting. Just my 2 cents...
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
2012 Pro Angler 14 (owned now by a good friend)
2013 Pro Angler 14 - Dune
2015 Pro Angler 14 - Papaya
PostPosted: Fri Nov 15, 2013 10:29 am
X2!!
PostPosted: Fri Nov 15, 2013 10:49 am
Thanks guys. I would be using it to hunt with so I was just curious. Thanks again for the info and I look forward to joining the club!
PostPosted: Fri Nov 15, 2013 2:43 pm
I keep saying I'm going to paint at least the front hatch lid of mine with Plasti-Dip just to see if it will stick. I'm pretty sure it will. I have friends that spray their cars, wheels, and dashes with the stuff just for temporary changes in color. It wouldn't be permanent but that's okay by me.
PostPosted: Fri Nov 15, 2013 3:20 pm
X3
badbill
2014 Hobie Pro Angler 14
Look into camp wraps
badbill
PostPosted: Sun Nov 17, 2013 10:30 pm
You can make a cover out of burlap & attach a camo net to it....add a camo dodger and youre set
PostPosted: Mon Nov 18, 2013 9:07 am
Check Cabela's (or probably BPS) website and search "camo netting". Several patterns and sizes that you could use to cover your yak when hunting, have a very visible yak for fishing, and none of the issues with paint.
2012 PA-14 Dune; 2013 PA-14 Yellow.
PostPosted: Mon Nov 18, 2013 12:48 pm
This video should pretty readily answer your question:
http://www.youtube.com/watch?v=pvHpveAoV8M
Proud owner of:
Lots of Hobie Fishing Accessories
Hobie Pro Angler 12
