It is currently Tue Apr 16, 2024 12:10 am
PostPosted: Tue Jan 14, 2014 3:54 am
acousticfarm,
I haven't been able to find my original pics you asked about, but these might give you a better idea of the DB in the cassette:
Folded back:
Lowered:
Top view:
You can see the cutting board layers which were shaped to fit the cassette. The shape for the DB was copied from the Adventure DB slot. The layers were bolted together to get the final DB holder. This was then bolted into the cassette and an aluminium sheet, shaped like the cassette was added underneath the cassette for a base for the bolts to go through. Eyebolts were added fore/aft as well as a cut down miragedrive axle for the locating pins. The cassette was then filled with a mix of lead shot and tile grout to add ballast.
As RR pointed out it worked well in the front drivewell of our old Oasis when we had two sails. If used with a single sail the best position was the rear drivewell.
A bonus with the DB, apart from stopping sideways drift when going upwind, is that it adds stability when sailing. With the DB in the down position, heeling is slowed noticeably, and you have more time to adjust the sheet in strong gusts. I always sail with the DB down when out in my AI in kayak mode (small sail but no outriggers ).
PostPosted: Tue Jan 14, 2014 1:58 pm
^very elegant solution!
PostPosted: Sun Jan 19, 2014 2:23 pm
Hey, I have an Oasis with sail kit, and have fund it easy to go up wind alone then together with some one. Have a go, it awesome to sail you kayak.
Life is GOOD follow us...
PostPosted: Mon Jan 20, 2014 10:10 pm
I agree. I stowed a couple of sandbags in the bow and have noticed that Blew Maru (my Oasis) is much easier to sail solo...And this is without installing the drive (in the down position) in the fore cockpit.
Longbikermike
sent by iPad using TapaTalk
Longbikermike
Valle Vista, CA
PostPosted: Sat Sep 27, 2014 6:50 am
Added this to my Mirge:
I used a Hobie 16 rudder with a stock Mirage drive locking pin.
Wil Thoms
Newport Beach
Hobie 16 with Tequila Sunrise sails (in the past)
Hobie Revo 11 for peddle, paddle, fishing and sailing
Hobie Eclipse 10.5 Solar Yellow
SurfTech 12' Touring SUP
