It is currently Fri Nov 17, 2017 11:05 am
 Post subject: Mast Track
PostPosted: Sat Nov 25, 2006 4:23 pm
On the way home from our last regatta the upper plastic part of the sail track was damaged. The speculation is that something on the highway must have hit and cracked the sail track. How hard is it to replace that part of the sail track? Expensive? It appears that their aren’t any fasteners that hold the sail track to the mast and it can be replaced without too much trouble. :?:
Abraham
Clicking on the picture should bring up a larger one.
 Post subject: track
PostPosted: Sat Nov 25, 2006 4:40 pm
I've got a section of track that I'll sell pretty cheap. Email me if you are interested... ddbrown (at) ncsu (dot) edu
I'll also give you the info on how to replace it (it is very simple).
Trey Brown
www.velocitysailing.com
2006 N20 1017
1998 H16 102698
www.sunjammers.com ftw!
PostPosted: Sat Nov 25, 2006 8:30 pm
Ouch :(
below is from FAQ
Luff Track removal and installation instructions
http://static.hobiecat.com/2010_archive/support/pdfs/38584001.pdf
Fleet 297
 Post subject: Worse than it looks
PostPosted: Sun Nov 26, 2006 9:33 pm
Take a close look at the photo enlarged. It looks like this is damaged extrusion, and not the comptip luff track. OUCH
2003 Tiger - Don Atchley
PostPosted: Mon Nov 27, 2006 6:20 am
Naw, that's the plastic luff track. It's very shiny and the flash makes it look like AL in the photo.
Fleet 297
PostPosted: Mon Nov 27, 2006 8:03 pm
Replacing the plastic comptip luff track is not that hard (the aluminum track is another story). Just be careful not to crack the fiberglass lip that holds the track on.
One thing though, I'm not sure how expensive a replacement track is, but I might try just cutting out the bad section of track (similar to the cut-out where you insert the sail in the aluminum extrusion). It doesn't look like it's a very long broken section. Use a dremel tool to cut out the bad section and file the area smooth. If the top of the mainsail bolt rope isn't frayed, it would probably slide right through.
