It is currently Tue Apr 23, 2024 12:52 pm
PostPosted: Sun May 31, 2015 9:01 am
Mirage drive sprocket Autopsy.......... I hope this helps answer questions.
I went to upgrade to the ST Turbo fins and came across this problem the mast and brass spinning in the plastic.
https://www.youtube.com/watch?v=rgSuGxuVdkc
PostPosted: Sun May 31, 2015 10:37 am
Just my observation in the video....it appears you were turning the shaft clockwise.....so it will tighten and not remove the mast....yes/no?
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sun May 31, 2015 11:14 am
[quote="Dr.SteelheadCatcher"]Just my observation in the video....it appears you were turning the shaft clockwise.....so it will tighten and not remove the mast....[/quote ]
:wink:
PostPosted: Sun May 31, 2015 8:09 pm
Dr. I probably just got turned around when taking the video. I removed 3 out of 4 with out a problem. DR. are you that guy watching a movie....."there is no way a hollow core door stopped a 7.65mm Walther PPK......"? ;p
PostPosted: Sun May 31, 2015 8:44 pm
Nope, not me!
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Mon Jun 01, 2015 12:34 pm
I must have jibed one too many times and caught the boom with my head cause there I am turned around again.
