It is currently Tue Apr 23, 2024 8:14 am
PostPosted: Mon Jul 20, 2015 10:39 am
Do the Hobie 20 tiller connector kit components (part #1953) fit a Tiger? I cracked an end cap on my Tiger (part #99220163) and am looking for a replacement.
Mark
2007 Hobie Tiger
PostPosted: Sat Jul 25, 2015 5:51 am
Ok, an update for anyone that's watching.....The Hobie 20 connector kit provides a tiller end-cap that swivels, made up of 5 separate pieces. My Tiger has a single piece non-swiveling turned aluminum end cap that appears to no longer be available. I've ordered the Hobie 20 set and have been told that it will fit.
2007 Hobie Tiger
PostPosted: Thu Aug 13, 2015 10:45 am
H20 kit is the same - the only difference is they swiveled - you can make them 'not' swivel to match the Tiger by removing the nylon washer inside and tightening it - BTW _ they rotate for H20 and I think it's better, the reason is that when they don't rotate - it causes the plastic cap to bend when lifting to lock one rudder - be careful not to break the plastic cap on the non adjustable end of the tiller crossbar - that is the most common issue with Tiger, because they don't rotate the tiller end caps - (Wild Cat they still can break, but you don't actually lift up the tillers - the system works in a different way, so having them fixed just makes more sense - but that cap still can break easily from use and time)
Jacques Bernier
http://www.hobie.com/
PostPosted: Sat Aug 15, 2015 2:57 pm
Thanks Jacques, the parts arrived and they fit the end of the Tiger tiller just fine but with a little slop before the rivets were installed.
2007 Hobie Tiger
