It is currently Mon Mar 18, 2024 11:47 pm
PostPosted: Mon Sep 14, 2015 5:33 pm
http://www.austinkayak.com/products/174 ... e-Set.html
Are these the correct ones? I can specify 'Tandem' but not year. Thanks.
PostPosted: Mon Sep 14, 2015 5:46 pm
Yep, the cradle set for the TI is the same for all years.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Mon Sep 14, 2015 5:52 pm
Just make sure you get the updated one for the 2015 TI
viewtopic.php?f=71&t=53809
[quote="JbernierThey do a little bit - but not a big deal. there is a new cradle design that we are just starting to ship now that has a modified shape to allow for the venturi drain to more easily slide past the cradle without getting hung up. But it's more of a hassle than a real issue.[/quote]
PostPosted: Mon Sep 14, 2015 6:11 pm
Ok. So, there are new ones for 2015. Thanks.
Can't tell if these are new or old.
PostPosted: Tue Sep 15, 2015 9:48 am
We made a minor change last year for the drain fitting to pass the aft cradle. All stock since last spring has had this feature.
The peaks in the middle are now flattened. If they all look (rounded) the same... you have the old ones.
