It is currently Thu Apr 18, 2024 10:00 am
PostPosted: Mon Jan 08, 2007 5:58 am
Hola, tengo un HB18SX, y la maniobra para bajar la vela mayor es laboriosa estando en tierra y perfectamente proa al viento.
Pienso que en caso de temporal o tormenta es casi imposible bajar la vela desde el agua. Es asi? Imagino con olas y vientos fuertes intentando destrabar el aro de acero. Hay alguna tecnica especial para esto? A alguien le paso una situacion similar?
Saludos
HB18-Hidalgo
PostPosted: Wed Jan 10, 2007 9:21 am
English translation of the question: (edited from Altavista Babel Fish)
Hello, I have a HB18SX, .and the maneuver to lower the main sail is difficult while ashore and perfectly pointed into the wind. I think that in case of weather or storm it would be almost impossible to lower the sail from the water. I can not see trying to loosen the steel hoop in waves and strong winds. Is there some special technique for this? Has anybody that a similar situation?
Thanks.
Be sure that the metal ring user to latch the sail to the latching mechanism at the top of the mast is attached with a twist shackle. Otherwise it will be difficult to un-latch.
(from the assembly manual with comments) To lower the main, untie the downhaul and slide the leading edge of the sail up the sailtrack a few inches. Next pull hard on the main halyard and the metal ring and the top of the sail will overrun the halyard hook, rotate the mast to the starboard (counter clockwise) than release the halyard. (If you can position the boat with the wind pushing the sail a little to port this may help to release the medal ring from the hook. Also if there is any twist in your halyard; pre-twist it so that the ring tends to twist away from the hook (to the port) when the mast is rotated to starboard. The sail should fall free of the hook.
I have not done this with the boat in the water, but it helps ashore. I do not know if this is any different with a new comp tip mast.
John Latimer
'79 Hobie18 - Magnum
Sail#4854
 Post subject: Sail Hoist
PostPosted: Wed Jan 10, 2007 9:30 am
There is a detailed description of sail hoisting technuque in the FAQ section.
http://www.hobiecat.com/community/viewtopic.php?t=371
PostPosted: Wed Jan 10, 2007 3:05 pm
If you pull the rotation arm toward the hook while pulling the halyard it will release and fall. By using this technique there is no way the sail can reattach. So again, boat head to wind. push or pull rotation arm toward hook side and pull halyard.
 Post subject: main
PostPosted: Thu Jan 11, 2007 11:20 am
Lubrique encima de la cuerda del perno con el aerosol del silicón. Utilícelo liberalmente, a veces ese las ayudas.
Sail Revolution
Join us on our new FB Page!
 Post subject: Thank you very much
PostPosted: Thu Jan 11, 2007 12:09 pm
Thank for traduction and information, i'm going to tray this recomendation.
Best Regarsds.
HB18-Hidalgo
